surging at idle
Old 08-04-2015, 09:12 AM
Hank85713's Avatar
Hank85713
Hank85713 is offline
surging at idle
Truck is 04 has been BP'd but did it before the BPng and continues to surge when stopped. Sometimes feels like the trans has not gone to neutral and it wants to pull forward. Other times it will surge while at a red light or when stopped for whatever reason. Does not do this underway. Any ideas what may be the issue? I have SG 2 and the rpms do not drop a lot and the other indicated functions have small if any changes, but dont know which ones to monitor for this. No stalling or anything just the surge and the feeling it has not dropped out of gear at some stops.
TIA Hank
Old 08-04-2015, 09:14 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Post ICPV @ Koeo
Old 08-04-2015, 09:52 AM
WatsonR's Avatar
WatsonR
WatsonR is offline
Mine was doing the same, feels like it wants to take off occasionally? RPM don't change much, just a feeling like it kicked into gear and then back out?
A/C system was low on freon and when the clutch kicked in, took more than it should have needed to get the A/C compressor spinning... it's a drag on the belt. Truck is adjusting for the load, don't notice underway because RPM is up already.
Old 08-04-2015, 01:31 PM
04badford's Avatar
04badford
04badford is offline
All of the above ,also do you hear the turbo spool up,
Old 08-05-2015, 10:53 PM
Hank85713's Avatar
Hank85713
Blade:
KOEO ICP 5-6
IPR 14.8
at idle ICP 581
IPR 24.2
Old 08-06-2015, 02:10 AM
bismic's Avatar
bismic
bismic is online now
Received 2,469 Likes on 1,711 Posts
Will it continue to behave the same way with the ICP unplugged?
Old 08-06-2015, 11:14 AM
BLADE35's Avatar
BLADE35
Originally Posted by Hank85713
Blade:
KOEO ICP 5-6
IPR 14.8
at idle ICP 581
IPR 24.2
The Idle IPR% at 24.2 is high
Was the EOT at 185* or more
We need ICPV (volts) @KOEO
Old 08-06-2015, 11:10 PM
Will Bite's Avatar
Will Bite
Will Bite is offline
What should it read? Mine hangs around 22.8-23.3 when warmed up in park at idle.
Austin Ostipow
2004 - 2008 F150
02-29-2016 03:23 PM
ebbnflow
05-31-2013 03:08 PM
79bigblock
11-18-2010 10:28 AM
wreedZ71
2004 - 2008 F150
04-24-2008 08:04 PM
mark4564321
2004 - 2008 F150
04-03-2008 06:16 PM
Quick Reply: surging at idle
