Inherited a 95 F-350 7.3 Turbo Utility Bed & 2.5k Crane
I just inherited a F350 Xtended Cab (part of settlement for loan to friend who passed) Hasn't run in about 3 years. I'm a gas engine guy, with just enough knowledge to get in trouble.
I replaced batteries, front universal, and solenoid on fender wall. A few taps on the starter and the ole screw driver and we got her turning. Little starter fluid and she started for 5 secs.
So far that's it. Gonna change fuel filter & clean water ketch. Recondition fuel in Front tank Diesel 911 & then add fresh fuel and then some Seafoam. Main concern is making sure oil is getting to turbo and it's ok. Once we get it running, then I'll get it to a mechanic to go through.
I am considering reverting it back to a 5th wheel setup for a trailer hauler. My friend, was s certified diesel & gas engine instructor @PTEC so he beefed it up suspension wise changed it to a utility bed w/2500lb elec crane on it cause he did a lot of Fleet repair & road calls on disabled trks. Sterling, Inter, Volvo, Ford ect.
I'm not sure what I'm gonna do yet, gotta see what we have first. Have I covered the big stuff in rejuvenation process?
^^^^ what he said. 3 years is a long time I would recommend going ahead and changing the oil. It is the life blood of these engines. On top of the engine, right behind the front accessories, pretty close to center there is a reservoir for the high pressure oil system. There is a fill plug on top. Pull it out and verify the oil level is about a quarter inch below the top of the reservoir.
I would discourage the use of starter fluid as well. It is not the best for diesels
Congrats on the new truck
Well, replaced solenoid, got her running and idling, but we forgot to make sure the fuel gauge was right. Nada in it so I've put 10 gal in and some diesel 911. New prob is it won't start with the key. Key turns on but no starter connection. I heard there may be a fuseable link in that line. Haynes shows 2 possibles, but not where. Not even sure that's it. Time to break out continuity tester. Thanks.
Received 3,101 Likes
on
Thanks, I'll chk those this wk when I get bk ovr there.
It has to be in that circuit since solenoid is ok - 1 of the 2
I'm replacing a M5OD-R1 in our 94 Ranger Splash right now, and then a front trans to drvshft universal on our 84 F 150 4 x 4 clunker
Love my new Tiger Tool U-Joint remover, it makes it so easy & you don't have to drop shafts to remove. 15 - 30 min max.
97f250 7.3 4x4
13
02-10-2015 07:34 PM
83capril
62
11-23-2014 06:21 PM
irontom
28
05-05-2009 11:10 PM
