1984 F250 interior compatibility
I'm restoring (not to factory) an 84 F250 XL and I have searched the internet, to no avail, for the years and models that would help me replace the front and rear bench seats (matching bolt configuration). If I knew the range of years that they matched, it would make my salvage search go a lot smoother. I also have door panels, interior molding, dash and a head liner to replace as well if there are any ideas on those as well. Thanks in advance!
on
The only 98 F250 is the goofy 7 lug overgrown F150, 97 is the end of the line for our chassis, however they were built quite late(a friend has a 97 MY by VIN F350 crew with a 1/98 build date) and the 99's were introduced very early.
Being this is a 250, I am going to assume extended cab. Pretty much any 80-96/7 ex cab donor will work for the front, my personal favorite is the 92-96 40/20/40 seat. For the rear, I think you can swap them as well. I'm a bit fuzzy on that though.
on
they made 3 "different 40/20/40 seats
The reg cab and crewcab(4 doors) are interchangeable. The only difference between them is the crewcabs have map pockets and a rear ash tray. the reg cab have carpeted backs and no ash tray. They both bolt in with 4 bolts like a bench seat does
the SUPERCAB trucks 40/20/40 bolt in as 3 separate pieces. you set the center section in first then each outer seat. In inside foot of the outer seat overlaps the center section. Then 4 bolts per outer seat hold them down.
Bench seats from 80-96(and 97 F350HD and F350) all interchange. Does not matter if from Bronco, reg cab, supercab or crewcab
As for interchangeability, stick with 80-86 and you will be right on other the the slide locks on the 80 trucks door panels
Also, someone mentioned LMC(Likely Made in China), unless you want to cheap part that is poor quality and not very good fitting I would stay away from them. I suggest looking into NPD(National Parts Depot), Bronco Graveyard, Blue Oval parts and Dennis Carpenter
Jchobby
04-30-2015 07:36 AM
77Custom100
04-21-2005 09:55 PM
