Two-wheel drive lift recomendations
I have a 2002 V-10 2WD Excursion and I am wanting to do a 4-5" lift and change out the wheels and tires...for appearance and better ride purposes. I was asked about "suspension" currently on her. Standard on these models is rear axle and front is independent? Any suggestions across the board? I have seen mostly 4WD on this thread. Thank you.
ProComp offers a 6" that allows for 35's and rides pretty nice, Razzi has it on his 7.3 and I didn't have any complaints when I drove it.
You are correct on the 2wd, but it's not technically an IFS setup - it's a twin beam.
Somebody recently swapped in a set of coils and leafs from a newer Super Duty but it didn't provide the amount of lift you're after. The suspension can't really just be spaced down like a standard leveling kit due to the requirements for drop brackets and whatnot for the suspension type.
Wow, I didn't even catch that and I usually do...
No harm no foul Traditionole, this thread may be helpful for you if you're not familiar with the online forum community in general
https://www.ford-trucks.com/forums/8...ead-first.html
