Torque Shift 2-3 & 3-4 Flare
Hey Guys,
I've been dealing with this flare for a little while now, didn't pay much attention to it until I started to feel it on the 2-3 shift as well. I know that I can change my shift pressures with my SCT, but I really would like to get this figured out and not "mask" a problem if 1 truly exists.
I'm not really good with trannies, but I was hoping someone can point me in a direction. I've done a general TSB search and I did replace my DC solenoid thinking maybe that would help with the 3-4 shift but it didn't change.
The truck has no codes in it and fluid is full and clean, last year when I pulled the pan to do a service there was no debris or discoloration in the pan or in the external filter or housing. Also my temps seem to be in check with the highest I see towing is about 190*
Sarge
Sarge
I had a similar problem before my tranny went, What caused it was The Manual Valve had been worn and I would loose pressure. I had a delay from P to R & D, It finally went and wiped out the TC and burned all the clutches.
I mot saying thats you problem but I would get it checked out before it cost you $3,500 plus......
If the intermediate solenoid were the problem it would have to be slow to apply and too fast to release to create a flare on both the 2-3 and 3-5. Is it possible? I can't say it's impossible, but it seems improbable.
The theory that the manual valve is leaking seems more likely to me.
