One wrong size tire
One wrong size tire
2000 F150 XLT 4X4 - I got a flat on drivers side rear tire yesterday. I bought the truck month ago and when I got the spare down, I saw it was a different size. The spare is 265/70/16. The 4 tires on the truck are 235/70/16. Can I put the larger spare in the front and drive it until the end of the week? I won't engage the 4x4. And the rear is non-posi. Thanks.
If you're on a short trip to the tire repair shop it really doesn't matter where you put the different size tire but on a long trip or towing heavy it's generally better to put it in the front. Having two different sizes of tires in the back will cause the spider gears in the differential to be constantly spinning, if you have A limited slip differential the different size tire should always go to the front for any trip of significant distance.
Yes, 235/70 is the size of the tires I bought it with. Should they be 235/75?
I only needed to drive the truck today. I'll be getting a new tire in Friday along with a matching size spare. So, it'll sit til then. From what I was told by a mechanic, running with 1 odd size tire would be fine temporarily as long as its not a posi rear, and as long as I don't engage 4wd.
Sorry but pretty much disregard anything I said on tire size, I was thinking of 235/85/16 vs 265/75/16 which are more common on older Super Duties, they are the both same height and not likely the tires you are looking at. The original tire size for the truck should be on the door sticker on the driver side.
fasthauler
08-07-2007 11:24 AM
