Broken Rocker shaft on a 390
Old 01-23-2016, 09:00 AM
stevejohnson48's Avatar
stevejohnson48
stevejohnson48 is offline
My 390 sets in a V-Drive boat
If you haven't already you can purchase the rockers arms and shafts ( at Rock Auto )along with springs sold separately ?// I think last time I looked the shafts were $26.00?// There is a oil deflector that fits under the shaft pedestals if you don't install ( None adjustable rockers ) it will increase coil bind ??/ And if your mechanic installed 428 springs this might be a problem ??/ I always wanted to install adjustable rocker arms ( cost didn't allow )it takes the guess work out of some of the rocker problems ??/ That and spacer springs between the rocker arms ( Weak link )??/ Replaced mine with aluminum spacers ??/ They used to be available at summit Racing ??/
Old 01-23-2016, 09:03 AM
stevejohnson48
Torquing sequence is always a key factor in any fastening on a long spread ??/
Marneaus
21
05-06-2019 11:40 PM
daddy172005
04-13-2009 11:58 PM
highrider76
19
04-30-2005 05:25 PM
original67
09-23-2004 05:05 PM
sdloe
13
01-05-2004 02:49 PM
Quick Reply: Broken Rocker shaft on a 390
