HELP - I dropped something in the motor. Am I screwed?
I'm working on finishing things up, after injectors and cups. All along I feared dropping one of the many tiny bolts,etc... in the motor.
It finally happened. I dropped one of the small oil rail plugs (the uvc ones) while trying to put it in. It went in the pushrod hole at the top of the head, on # 5 cyl.
I know. I should have plugged them with paper towels or something. I wasn't thinking.
Can I leave it in there or am I completely screwed now? I really need to get this thing running tonight, or I'm going to be without it for at least another week.
on
Hopefully it is sitting on the top of the lifter. I assume that the push rod was out? You could try to fish it out with a small magnet. Not sure what the diameter of the push rod hole is, but there are "screw starters" about the size of a pencil that have a magnet on the end. Just a thought.
Thanks for the replies. Oddly enough, I never received any email notification from the forum, so I assumed no one had replied.
I ended up pulling the rocker and pushrod out, and that gave me enough room for a magnet, and I was able to fish it out. This motor has gigantic pushrod holes, compared to anything else I've ever seen.
Whitey Ford: Very cool! Thanks for the tip. Check out this website:
Neodymium Magnetic Pick-Up Tool w/ 26" Telescoping Body - CMS Magnetics, Inc
We use these flexible ones where the magnet remains inactive until you push the plunger to activate the magnet when you reach the object you desire to retrieve.
Bendable Magnetic Pickup Tools - Master Magnetics, Inc.
