Is this the right steering shaft ujoint?
Old 08-02-2015, 04:55 PM
william16339's Avatar
william16339
william16339 is offline
Is this the right ujoint for a 79 f250 steering column? Moog MO265 U Joint | Auto Parts Warehouse
Old 08-02-2015, 05:04 PM
redroad's Avatar
redroad
redroad is offline
Old 08-02-2015, 05:22 PM
bkaul's Avatar
bkaul
bkaul is offline
IIRC, some of the 4wd trucks had U-joints? Or is that just a common modification the 4wd guys do?
2wd trucks definitely have rag joints.
Either way, the Moog U-joints linked is for a drive shaft, not for a steering column. The ones on columns that have them are much, much smaller than that, and probably not easily disassembled to just replace the cross-piece.
Old 08-02-2015, 06:00 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
X2 on your link is for a rear d/s u-joint. If you need a u-joint for a 4wd steering shaft ck out Flaming River or Borgeson, they have complete replacement steering shafts.
I do not think the OEM shaft will come apart easily to replace just the u-joint?
Steering Universal Joints
Borgeson Universal Company :: Ford Truck 1970-04
File Type: pdf
Old 08-02-2015, 06:02 PM
redroad's Avatar
redroad
redroad is offline
For the record the slop is usually in the rag joint
Old 08-02-2015, 06:21 PM
william16339
My 76 has ujoint not rag joints. I don't want to run a rag joint on a truck with 44s. But I guess I have to. I wanted to swap the ragjoint to a universal. So for now I'll put the rag joint by the steering column. (New rag) and use my old universal on the bottom until I buy one of those links with ujoint a on both sides... Thanks guys!! Are rag joints strong enough for 44s ?
Old 08-02-2015, 06:34 PM
william16339
78-79 bottom steering column bearing??
Ware the hell do you find the bottom bearing in the steering column of a 78-79 f250 manual. It's not the bigger bearing in the auto column, it's the smaller white plastic one ... Napa doesn't have it and lmc isn't specific enough to tell me what I need so please help
Old 08-02-2015, 06:51 PM
77&79F250's Avatar
77&79F250
Jeffs Bronco Graveyard....
Old 08-02-2015, 06:55 PM
william16339
Couldn't find it
Old 08-02-2015, 07:30 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
JBG has a kit to put a real bearing the bottom of the column. Even when new, the plastic bushing has a lot of slop in it.
Column Bearing, Lower 1976-79-Broncograveyard.com
Old 08-02-2015, 07:36 PM
77&79F250's Avatar
77&79F250
Bam! mikeo0o0o0 to the rescue like always.
Old 08-02-2015, 08:22 PM
william16339
Thanks again mike. Saw ur post on the other thread. Thank you.
Old 08-02-2015, 08:24 PM
william16339
You guys think if I run the ragjoint on the top and universal on the bottom, would that be a safe combo with 44s? A bit Leary with the steering. I don't feel like wrecking my truck or myself from something stupid.
Old 08-02-2015, 08:40 PM
redroad's Avatar
redroad
redroad is offline
It has both doesn't it ?
With 44" tires I wouldn't run a rag joint .. That's something you should have thought about way before the 44es but the good news is you can do something about it now .. The OEM steering and brakes were never engineered for 44s .. ..
I would"t even drive it without the Borgeson heavy duty shaft set up, a redhead steering gear and the column bearing upgrade with those 44s .. You didn't think mentioning the 44s was useful info ? How long have you been running with the 44s on the truck?
Old 08-02-2015, 08:49 PM
william16339
Bought it with 44s. Actually stops pretty good. Steering is good except for the steering shaft. Upgraded box and tirods. Cross over steering.
Quick Reply: Is this the right steering shaft ujoint?
