Champion Radiator/Lincoln Mark VIII fan = PERFECT fit
Just thought I would put this out there, but the Lincoln Mark VIII fan (which I'm sure we're all familiar with) is a PERFECT fit with the Champion Aluminum radiator that is made for our Dentsides. I mean LIKE A GLOVE, it just fits in there perfectly. Just got a couple pieces of aluminum angle and ran a couple screws through the bracket on the rad, then down into the fan housing ... not sure if the fit is as easy with a stock radiator, but man - it blew my mind how easy it was to do this.
(BTW< my entire build is on youtube under the channel name "Apocalypse Bob")
Wow, that looks great. I bought a 4 core Champion and their twin 12 inch fan kit. The radiator is great but their fan kit SUCKS! Kept overheating bad. I cut up the shroud and used it to mount a 16 inch fan from summit that I had and that works well for now.
Where did you get the fan? I think this is the route I want to go.
The Lincoln Mark VIII's had the best cooling fan like ... basically ever. Problem is a LOT of people know about them, and most of the Mark VIII's in the boneyard have had them picked out. If you're lucky, you can snag one from Pick-n-Pull for about $20. If you're not lucky, they can be had for 70-ish bucks off of eBay with a fair bit of regularity. Be warned though - you better be rocking a 3G alternator as well, cause they suck some juice.
So I have read....Lincoln Mk VIII two-speed fan, Taurus or Lincoln cars.
A 95 Mercury villager minivan with a 3.3L V6. The stock radiator for this thing was a gigantic three core all aluminum radiator. However, the fan for this was a gigantic 19" two speed fan. This thing is massive. Bigger than a mark viii. If anyone's interested, I did some research the 92-2002 Villager is a rebadged Nissan quest.
Mine is a 2 speed- easy to tell if it's a two speed (three wires)... Wiring it up will be a while other story, I'm basically going to have a handful of relays and two sensors. Trigger
High/low at different temps, and have a manual bypass on the dash (as opposed to hooking that I'm through the AC)
I've heard of the vans with those giant fans - and know the taurus fans are popular alternatives- I mainly made the post so that if anyone had that specific radiator and was looking at fan options, the mark viii is a spot-on fit that you can do with two pieces of angled steel, a dozen screws, a power drill, and 20 minutes. Passing along the good luck!
totally agree. Personally, I don't think there is much excuse NOT to have the 3G upgrade at the top of your list no matter what. You can do it in a couple of hours and the alts can be had at the junk yard all day for like $15. Most junk yards are a sea of ford Taurus
champion
(68-79) F-Series Truck 4-row Champion Radiator
MC433
<table class="product-viewer"><tbody><tr valign="top"><tr><td style="text-align: center;"></td></tr><tr><td style="text-align: center;">Click to enlarge image(s) </td></tr></tbody></table>Champion All Aluminum Radiator
4-Row Core Polished Tanks | Cools up to 800hp
Radiator Dimensions:
Total: 26.5" tall (with cap)x 29.5" wide (including brackets)
Core: 19.25" tall x 26.375" wide x 2.75" thick
Inlet: 1.75" passenger side
Outlet: 2" driver side
Tanks: 3.25"
Tubes: 0.63" thick
Bracket Mounted
Radiator Cap Included
Transmission Cooler Included
Aluminum Shroud is also available
When using electric fans:
Two 12" Electric fans recommended for this core size
MC433
Tanks: 3.25"
Tubes: 0.63" thick
Bracket Mounted
Bigbluedent1977
08-29-2016 07:49 PM
302flareside1992
35
07-29-2010 06:58 PM
ceetwarrior
08-25-2005 07:26 PM
proeliator
03-19-2003 03:29 PM
