1979 f100 custom wheel size help
Just bought a 1979 f100 custom. Its been in the shop 4 weeks having work done but when it comes out it needs new wheels, the prior owner has on these funky too wide things, sorry no image as I don't have the truck.
Question, what it the correct wheel size for this model and what is recommended to maybe improve the look?
The truck will remain stock in looks per se so nothing outrageous.
NOTE: Axle tag location and appearance may vary by application
Ford Rear Axle Assembly Identification - Page 03 - FORDification.com
Is your F100 2wd? If there is still a tag this should get you there ..
Hollander shows many wheels for the 1979 F-100
C5TZ1007D, 15x5-1/2"
E3TZ1015U, 15x5-1/2"
E3TZ1015V, 15x5-1/2"
E4TZ1015C, 15x6"
D7TZ1015A, 15x6" (5 slot aluminum)
D8TZ1015E, 15x6" (10 spoke aluminum)
D8TZ1015B, 15x6" (white 8 spoke steel)
D8TZ1015C, 15x6" (yellow 8 spoke steel)
E2TZ1015B, 15x6" (argent 8 spoke steel)
E3TZ1015W, 15x6" (white 8 spoke steel)(obsolete)
E3TZ1015X, 15x6" (argent 8 spoke steel)(obsolete)
This is all you need to know. All '79 1/2 tons left the factory with 15" wheels, regardless of engine, transmission, or rear end gear ratio. A slightly larger tire (235/75-15 for example) might give a minute deviation on the speedometer, but really no other significant consequences. And, these tires could be mounted on 6" to even 8" width aftermarket wheels.
For wheels you might well find a decent set at the JY.
If you want new, Summit is a good option. Select your wheel size and bolt pattern and you will get lots of choices including unpainted steel wheels.
That is what I did to replace wheels on my F250. I went with US Wheel steelies for near stock tire size.
Scotty's 52 F3
18
09-18-2015 06:13 PM
Mdc9966
06-04-2015 07:23 PM
MarshallCountyMS
05-18-2015 12:59 PM
crazy96863
23
08-04-2012 02:38 PM
