I have a serious question???
Received 3,090 Likes
on
if your 91 is a 4X4 no. the 2015 has coil springs in the front, the 91 has leaf springs.
and the rear is a different width, i believe it is 1 1/2 inches wider than the 91. so the springs will be twisted a bit.
plus the driveshaft will have to be modified for the universals to work. and the brake system will have to be modified to work with the rear disc setup.
can it be done?? yes. is it worth it??? probably not.
A complete suspension system for $100? Even if it doesn't fit, jump on it!!! You could part that out and make a lot more than $100. Maybe even enough to upgrade your current suspension.
lightningmatt
02-03-2007 01:55 PM
