Hot August BS Thread
#49
#51
on
Didn't yet...
I tore apart some of the interior now but not so bad we can't use the camper..
Yup... Slacked most of the day under the camper with a stiff brush, paint, RTV, Undercoating and black foam sealant.... Well, at least it won't be dripping rust now...
I put a new dehumidifier inside the camper and have pulled over a gallon of water out of it in less than 24 hours...
Worked on the condensation tube for the fridge too.. I extended it and ran it through an opening in the outside grill.. It used to just drain on the floor and drip through to the cabinetry under the fridge where I found a giant bunch of mold cooties...
#53
on
Didn't yet...
#54
on
I'm slowly turning it into the camper that I thought it was to begin with. I am really convinced that no one builds a camper that was expected to last more than 10 years.. Staples, glue, crappy luan, etc...
The interior -
I pulled the booth out and smashed it.. Left the table though and now have 4 chairs that will go in there.. The hide-a-bed is next and we'll buy a power leg lift love-seat with a center console. It will fit - just not with a lot of room to spare. Also redoing the ceilings and walls of the living-room and bedroom slides. We found some really nice lightweight carpeting that will be used. Lighting will be mostly LED.
Here are some pics of the fridge work..
Mold cooties -
Before - (see the white plastic convoluted tubing? It's the condensation line.. Just left to drip on the floor behind the fridge - dribble through a hole in that floor and down to the floor behind the cabinet.. Ugh...
After cleanup -
Condensation tube now run through the grill of the fridge..
The interior -
Mold cooties -
After cleanup -
#55
on
The interior -
Mold cooties -
After cleanup -
The interior -
Mold cooties -
After cleanup -
#56
No, unless you spend well over 100k, you aren't getting a long term unit. Maintenance is obviously important too, if they get wet you are done. Going forward I will buy a new one every 5 years. Having a 5 year warranty each time. Not willing to fight it anymore...
Keep the pics coming. You're doing a lot of work.
#57
on
After seeing some of the campers and deals you guys got, it was really tempting to throw in the towel... However, being on a somewhat fixed income right now and probably the foreseeable future, I've had to choose my current path.. I am hoping that the walls are not too bad..
The bones of this rig are good though.. It's a steel superstructure as best I can tell. The walls are fiberglass over foam core with luan inside. The studs are wood, but their spacing is unknown.
If something changes for me financially, I'll have a pretty clean unit to trade in....
