injector ?
When you say "no codes" does that mean no codes as in no reaction from the computer? or no codes as in you get "system pass" across the board?
Someone set the base timing without pulling the spout jumper first?
Pinging suggests the timing is to far advanced, a condition that would result in low power even surge some if far enough out ahead of where it should be.
Set base timing to 10btdc with spout removed, then while watching timing mark remove and replace jumper verify computer has control over timing. Probably does but a quick easy test to make sure its doing what its supposed to a minute.
i have played with the timing and still get the same if i retard the dist it has no power and if i advance it it pings worse and no power. i have already changed the timing chain and it was very stretched and have pulled codes and got system passed. also no vacuum leaks this has been an ongoing problem that started out as pinging on big hills and has gotten progressively worse to the point that its not drivable and i don't want to buy injectors without making sure that is the problem.
ok here we go and i may forget a few things that i have done. new plugs all clean, fuel filter, fuel regulator, coil, wires, cap and rotor, egr valve, tps, mass air flow sensor, dist, ignition mod, pcm, timing chain, the cat has low back pressure and new o2 sensor 180,000 miles and good compression all in about 2 years and if it was compression it would not idle good
Snap the throttle open a few times with the line on you should see the pressure rise.
When I did a compression test of my 5.8 my highest reading was 148. Most of my cylinders read 140 or less. Then again my truck had 203,000 Km when I did it.
I hope this helps.
