1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Exhaust Filter HELP
Old 07-30-2015, 08:02 PM
Billy Percival's Avatar
Billy Percival
Billy Percival is offline
Exhaust Filter HELP
I am working out on a small Pacific island and we have 2 new F550's .
Have the "Exhaust Filter Over Limit Service Now" message come up on one .
Now we have tried doing to recommended drive to clean a few times here on both trucks , but it is very difficult . The island has rough pot holed road (there is basically only one and only about 12 miles of that) and a fair bit of traffic .
Driving at 30mph for any length of time is pretty tough to achieve .
Now the message tells me to take the truck to a service place … we good luck with this !! Nearest Ford dealer would be Hawaii or Guam maybe .
The truck in question has only 750 K on it less than 500 miles
So what can we do ? Any way to clean the filter ourselves , but then of course there will be the engine management to clear .
It has not gone into any shut down on power .
Fuel should be OK quality wise , but I am guessing there really .
I have seen after market controller things for sale like H&S Black Maxx and replacement pipes , but don't totally understand these .
Things are pretty basic here , really basic , but we can work through I guess with help :-)
Thanks in advance for any advice
Billy
Old 07-30-2015, 08:37 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
We need more info on the engine as to which one you have. Also might ask these questions in the engine section as those folks are great with engines. Being a new vehicle look at the service area of forum there is a direct line to ford via private message.
Old 07-30-2015, 08:54 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
have you tried running the engine at a fast idle to see if it will initiate a regen cycle to clean the filter? I remember some guys with class 8 trucks talking about how they had to sit on the side of the road for an extended period of time while the exhaust filter cleaned.
I hate to say it but a newer DPF equipped diesel engine is probably not going to give good reliable service with your type of use. These engines need to be taken out and run in order to keep the emissions system clean. Short distance driving is tough on any diesel but it's a lot worse with this newer stuff.
Old 07-30-2015, 08:56 PM
Chad149's Avatar
Chad149
Chad149 is offline
Being you have F-550's you can install operated commanded regeneration (OCR), basically a switch that puts the engine at a high idle and performs the "exhaust cleaning" (aka regen for short) while stationary. I haven't looked into adding one, may still require truck to go to dealer to program it into the trucks network.
The other thought I had is have you been seeing white smoke? If so, you might not have ultra low sulfur fuel, which will also not end well for the filter (aka diesel particulate filter, DPF). In this case your only option is a delete kit from H&S or similar company. This will void warranty, but also would not require truck to go to dealer either.
Good luck, and welcome to FTE.
Old 07-31-2015, 04:54 AM
bigredtruckmi
Remember the op would have to take the rig to a to ship via over ocean to get to dealer. He is on a island in Pacific.
Old 07-31-2015, 05:24 AM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
operated stationary command is the answer.
Or delete the emissions components.
Old 07-31-2015, 07:35 AM
93-331-29PSI's Avatar
93-331-29PSI
93-331-29PSI is offline
Maybe your company can work a deal and fly a ford tech out to install OCR software. Given the conditions there a V10 gas version 550 would have probably been a better choice in vehicles.
Old 07-31-2015, 09:17 AM
senix's Avatar
senix
senix is online now
look at something like this
EEPod LLC
milkweed.gardener
2017+ Super Duty
32
07-23-2018 10:11 PM
Lil02Ranger
6.4L Power Stroke Diesel
03-05-2015 11:09 PM
motivationteam
6.7L Power Stroke Diesel
45
08-18-2012 06:59 AM
wesfire911
03-19-2011 06:26 AM
BigBri BigBri
01-09-2011 04:46 PM
Quick Reply: Exhaust Filter HELP
