AC Vacum problem
AC Vacum problem
this doesn't make any since to , what's going is, sometimes the AC starts blowing warm air, I found out if I goose it I can hear what sounds like the damper door slamming shut, then AC starts blowing cold again. I changed out electric vacuum pump, but it still does it, starting to get worse & its hot.
Truck is a 2002 f250 powerstroke, the way I understand it, is only thing vacuum pump is supposed to control is AC & 4 wheel locks, my truck is only 2wd. I don't understand why when when I goose it ,it goes to working, what can I do to fix this, any help will be appreciated THANKS
I just found out the " heat and cool "adjustment is electrical, not vacuum, it goes to something under dash, but I have no idea what it is, heat strip, reastat(sp)??? where and what damper am I hearing. It is not like heater is on ,not that hot, feels like ambient temp, im at a loss
I thought I found & fixed problem ,but no. it didn't work, I took electrical box off what I think is blend door ( electric control box works) I put a piece of key way in door slot & ty wrapped it closed, I took cover off heater core,so I could see what I was doing, the key way fit good & would & close door. But it is still doing the same thing, Any ideas, I need help Thanks
hank_48
18
07-29-2005 01:08 PM
