View Poll Results: Do I replace the injectors?
Replace injectors!
100.00%
Do not replace the injectors!
0%
Other: See Below!
0%
Voters: 3. You may not vote on this poll
New injectors - Poll
I am doing a compression test this weekend....
When I get positive result (power of positive thinking), should I do Injectors while I am in there??? New glow plugs are in hand...I will be inspecting everything while it is apart.
If the numbers come back bad it is getting punted to the corner...
230,000 miles on the truck, bought it 2,000 miles ago so I have no idea if they are new, used, or original.
I know most people say if it isn't broke don't fix it... but I HATE taking something apart, putting it back together and then having to take it apart again for some other reason!
With good numbers the other repairs that are already planned are up pipes, turbo rebuild, new boots, uvchs, maybe billet plenums.
As a side note the engine is out of the truck of the truck for a transmission rebuild and leaky oil pan...
If you want to stay stock you could send them to Jim @ Rosewood Diesel to test them for you and repair if necessary. If you want to get bigger ones, make sure you have a plan for the truck. The bigger the injector, the more supporting mods you will need. Just don't want to have you throw your money away on parts that you will want to change again if you get a bigger injector.
Received 3,102 Likes
on
MK_snipe
24
05-25-2016 04:24 PM
ScottInTexas
02-18-2016 04:52 AM
Firefighter 1406
16
10-24-2015 09:48 AM
