Battery Size
on
Battery Size
Living in a cold climate, I usually change out my battery every 4 years and sell the old one on KIJIJI while it still has some life in it and it's about that time.
Original Motorcraft is a 750CCA but the dealer also lists an 850CCA that apparently fits exactly on the same battery shelf for a few more $.
Anyone got the 850 and is there much difference? Was it worth the extra $$ ??
Truck has always started fine with a 750 even at -20 degrees. Would the 850 be cheap insurance or a waste of money i wonder?
One thing I always consider with any battery is the length of warranty, and the number of places I can make use of that warranty.
Fact is all brands can fail, and none of them are as well made as we'd like, so chances are you can have a premature failure.
Some folks choose wal-mart batteries for this reason. Around me, NAPA is the most common place, so I usualy buy those for that reason. I have made use of the warranty and it took some of the sting out of having a failed battery.
That being said, if the price is anything close, I'd always go with the higher CCA rating. But here's a question I can't answer. How do they get more amperage? Thinking of this like an RV'er, I wonder if they use more, but thinner lead plates, in which case, is that battery actually more likely to fail? This is pure speculation on my part.
There are tradeoffs. If we're talking the same size case, then for a given CCA rating the larger cold cranking amp battery will have more/thinner plates, to provide for a bit more juice when starting.
But, higher CCA comes at the expense of reserve minutes, and they are also more easily damaged in rough service (Off Roading) ; if you want the "best" what you really want is the heaviest battery that will fit, with the longest warranty.
Unless you absolutely need the highest CCA, there are better choices in my opinion, particularly if heavy draw accessories are being used frequently.
Not with our battery management system. I've heard of AGMs lasting 8-9 years, which is double a "normal" lead-acid battery. They charge fine with the lead-acid chargers, but like a lower float. That's where the battery management system in our trucks should keep it happier than in a "regular" application.
