1985 F150 5.0 EFI Fuel Filters
Yeah, I think that may just be the Quick Disconnect between the fuel line and manifold plumbing... if that is what I'm thinking, it operates like A/C connectors and you use these little push tools to unhook them....
6 Piece Fuel Line and A/C Quick Disconnect Tool
Don't you have the fuel supply and fuel intake lines reversed?
Anyway, that seems odd. How would that piece be on the wiring harness containing the fuel injection connectors? As you see in the pic I included, that piece I'm referring to is on the fuel supply line.
See - it's in the fuel supply line.
I'll look in the parts catalog and see if I can find anything useful; I don't have any service manuals for anything with EFI, though.
This is the drawing (way down at the bottom) from the parts catalog, I highlighted in green what I think you're looking at.
Basically, you have an incoming fuel line; a tube (9F754) that connects the left & right rail; and a return line.
I'd guess the incoming fuel line connects to the rail on the passenger side.
9C968 is the fuel pressure regulator; the cylindrical object I think is just something substantial to grab a hold of and connect/disconnect the two tubes.
These connections all look like the kind used in air conditioning... see if this video helps you (he uses a nicer tool than those plastic things I showed you earlier):
Yes, thanks for the trouble of posting these. I've seen that video before. It's funny because the guy stops it when he has trouble with the spring clips. Then suddenly he turns the camera back on an viola!
I'm satisfied that the piece I'm talking about is what you say. Seems too small to be a filter anyway.
1985 f150 5.0efi dual tank fuel rail?
I'm at my wits end. I have tested everything from the tanks up to and replaced the pressure regulator. Shortly after replacing the regulator it quit running all together. So I cut the rail (OOPS- Didn't realize they are almost impossible to find!) just below the regulator and hooked up an external fuel pump. I get plenty of gas through the regulator into the rail ( I know this because when I pull the line off ), and hear the injectors rattling, so I am assuming the electronics are working correctly. But the beast won't run unless I prime the intake. HELP???
Yes Steve, that is a fuel filter, here is the one I took off my 85';
That blue hose (PITA), I believe was heated, when the Filter was installed originally. The filter is obsolete, but you can put an aftermarket inline filter there. I have only seen this on the 85's, EFI. I have a thread on this somewhere.
I put a "T'" fitting Schrader Valve in there to check fuel pressure since the 85' fuel rail does not have a Schrader Valve.
