1985 F150 5.0 EFI Fuel Filters
So - I have heard that the 85 f150 5.0 actually has 3 fuel filters. There's one in the tank, there's one prior to the external pump, and there's one right behind the lower intake manifold and is generally hidden from view by the plenum. Anyone ever replace it? Know where I can find one?
Man, those lines are tight. Going to have to razor cut them to get the filter off.
One in the tank is a screen on the pickup for the pump. Don't know of a fuel filter at the back of the engine. The car engines (I think are the same as truck ones) have a PCV filter in the back of the engine, which hardly ever gets changed because a lot of people don't know about it. Follow the PCV hose down to the PCV valve. Remove the valve and grommet to access the filter. Hard to get out sometimes. I use a long sheet rock or sheet metal screw to pull out.
There are also fuel filters on these trucks that are in a housing. The housing unscrews. They can get stuck, I had to take the whole unit out of my ranger and put it in a vise to get it undone. But don't cut any lines.
I've already replaced the fuel filter in the tank. I also replaced the one in the canister that unscrews with an oil filter wrench. The one behind the plenum is very small and the fuel lines come into both ends. The are not connected as you may expect. The lines run tiny the ends that are barbed and they are as tight as I've ever seen. But there is not keeper. It's simply blue fuel lines that wrap around the barbed ends and they are incredibly tight.
Wait a minute...are you confusing the spring-lock fittings that plug into the fuel rail for 'tiny fuel filters'? Do they look like the fittings in the picture I attached? It's not from a V8, but the fittings are the same. You can see the hard nylon lines (which have been cut) going up to them. If that is what you have, it is not what you may have thought it is.
No. I am not confusing the spring line fittings with the fuel filter.
Literally, there is a blue fuel line that comes from the external fuel pump that runs directly into a very tiny (about 2 inches long) fuel filter with NO type of clamp whatsoever, and a blue fuel line that runs from it into a connector with a keeper that connects to the fuel rail. Those fuel lines are as tight as you can imagine. It's as if they are too small for the fitting, and were placed around the ends of the fuel filter and heated to shrink tight against the barbed fitting.
I couldn't find any filter such as you describe on Rockauto. Might be a good idea to go to a dealer. Or, maybe someone has a diagram. I'm not finding anything. If any filters are present in the system, you shouldn't have to cut any lines to replace them. What you are describing sounds like a "non-serviceable part.
I understand 1985.5 - 1986 have different fuel filters than prior versions; read through this thread and see if it helps you (fuel filter stuff is near the end):
https://www.ford-trucks.com/forums/1...4-5-0-efi.html
I am just concerned you're looking at cutting stuff apart that was never intended to be disassembled, and those things you think are filters are something else.... posting some pictures here might help. *hint* *hint* *hint*
This is where I was remembering in that thread, sorry I couldn't be more specific at the time I wrote that (was at work with limited time):
https://www.ford-trucks.com/forums/1...l#post15317418
OK, send me your pictures to ctubutis @ yahoo . com and I'll post 'em up here for ya.
