96 F250 5.8l
What do you consider mods? Headers? fancy intake tube? or heads, cam, stroke, compression?
Keeping the speed density, you can modify the chit out of it, but you will have to use a cam that produces good vacuum, so the map sensor can offer a vacuum range, translated to the computer in a way it understands. You can adjust for changes with larger injectors, calculated correctly of course, and use an adjustable fuel pressure regulator, along with a wide band. This wont be precise. To be more precise, youll either want something like the quarter horse or mass air, which, the mass air still needs to be tuned to be precise. Or there is aftermarket options for stand alone control.
Has anyone done a speed density to MAF conversion on a F series before? I know they are super popular with mustangs:
The Corral Tech
Pro-M Mustang Mass Air Conversion Wiring Harness (86-88) 5.0
The Corral Tech
Power of 8
11-06-2012 04:14 PM
TeddyY
05-13-2006 10:27 AM
TheRoadVirus
11-19-2005 05:42 PM
