It runs fine BUT...
It runs fine BUT...
('85 f250 6.9L) I have just replaced my fuel pump and return fuel lines because my truck was not running and had this same problem. The problem you ask? She pees while i drive (diesel drips at a concerning rate out the rear tank) and if i open the cap diesel rushes out.
Since it broke down last the fuel tank switch has not worked and is stuck on the front tank (which confuses me more to which why the rear tank is causing me problems)
Engine runs with no issue, except a random increase in throttle while accelerating (rarely).
I love you guys, please help she's my daily driver!!!
It's not that easy you will find out. The valve that just goes right in from Ford is very expensive if you can find it. The valve at the local parts stores will work, but the hose fittings are different and the wiring is a little different. But it's much cheaper and easier to get. Both valves operate the same, it's just one was custom made to order for Ford while the other is a universal valve, both made by the same company, Pollack.
donskrin
11-30-2015 08:27 PM
Mean Green 78
06-25-2009 09:15 PM
