Help!!! 6.0 nightmare
#166
#170
#171
So long as I don't have the tools not problem. They will even
let me bring the laptop.
They told me that even doing it for free infringers on there workers.
On the Southern border comment. This was Canada's boarder and not
the guys from US border. Hell even the US guys gave me some grief.
I do have one up side. My passport is about 5 years old and no stamps
till today. The US guys gave me an entry stamp.
Cheezit, correct me if I get this wrong.
On other points I talked to Cheezit for about 20 minutes.One thing
that came up is he said that sometimes in cases of stiction spool
valve may get stuck at the end of travel when hot and then dump the
high pressure oil.I also brought up what if a broker leg on one of the
snubbers in the stand pipe gets lodged in a spool valve in just the
right way to allow oil past and as the oil warms up more goes past till
you get a hot no start.
Here is the data sheet on that problem.
http://alliantpower.com/sites/allian...03-08r1_en.pdf
stiction and other stuff
http://alliantpower.com/sites/allian...01-09r1_en.pdf
http://alliantpower.com/sites/allian...02-08r1_en.pdf
http://alliantpower.com/sites/allian...01-08r1_en.pdf
At 4,000 PSI it does not take much of a nick on the O-ring to get a lot of fluid loss.
Here is a good training manual.
http://gershon.ucoz.com/FORD/51s08t1.pdf
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#172
Here it is
Corrected photo. This is the orientation that you
will be seeing on that side.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
#175
Boys, it's one thing to use anonymous user names to post "expertise" online. But, for Sean to put his have-tools-will-travel butt on the line, in front of this crowd, to help a brother in need - that's some strong stuff. Send me your PayPal, Firefighter, and I'll buy the beer.
#176
Ok so Sean knows, but the rest of you do not. Took the truck for a long drive on the highway. Brought it home and did an air test through the ICP. Heard nothing. Left it on for 5 min all of a sudden it starts pissing air like crazy! Got it down to fuel rain on passenger side but can not seem to find the exact spot.
#179
#180
