Help!!! 6.0 nightmare
08-16-2015, 05:35 PM
on
dang that sucks!
are they not letting him in at all, or just not yet?
08-16-2015, 05:56 PM
Quote:
Originally Posted by
Firefighter209
KOEO ICP is 5.4v
That shows Bad ICP Sensor
I assume its new
So bad wire or Incorrectly wired
Didn't you have SGII???
If so check the code programming
It should be .18-.24v range KOEO
08-16-2015, 06:01 PM
Firefighter209
Unfortunately no Canada Customs would not allow him in. They thought he was here to work.
If he can, show customs this thread!
it shows his full intent.
08-16-2015, 06:05 PM
Firefighter209
Wish they would do this at the southern us border
08-16-2015, 06:08 PM
Where did the ICP sensor come from
08-16-2015, 06:13 PM
Good call Benny. I have seen a mis-configured gauge give a similar reading as well (just something to check).
08-16-2015, 06:22 PM
We'll , tell Customs you Own a 6.0 and require to have this much tools to keep her on the road,If that don't work Tell them to go pound sand
08-16-2015, 06:41 PM
on
BLADE35
This one is a used one have another in a box. Will put it in and check voltage.
08-16-2015, 06:44 PM
Firefighter209
With any luck it may change it's mind
Atleast your is easy to get to
Was the pigtail to the ICP ever changed
08-16-2015, 06:45 PM
on
Even unplugged I have a hot no start.
on
Pigtail has not been changed to my knowledge.
08-16-2015, 06:59 PM
Firefighter209
I understand
But the truck thinks it has high oil pressure if that value is what the PCM is seeing
And if it wiring problem unplug won't help it
Also we could be chasing the wrong system
However you have classic HPO system symtoms
08-16-2015, 07:02 PM
on
Ok just tested the pigtail KOEO with a hand held voltage meter. It reads 5.1. Without the key on it reads .4
08-16-2015, 07:08 PM
That's your problem if you did it correct
I would have to check a wire diagram to be sure
Let me check mine right now key off never checked it that way
08-16-2015, 07:11 PM
Off SGII I can't get a reading key off
That reading is a bust anyway you look at it
