Installing a distributor
Old 07-29-2015, 04:46 AM
sgauvry's Avatar
sgauvry
sgauvry is offline
I will be installing a new distributor in my 1985 F150 5.0 EFI. I have found TDC using a handy little spring loaded gadget and valves are positioned correctly.
I have read conflicting methods of installation. One says to install the distributor at TDC with one tooth off of #1 (retarded), another says to install at TDC directly on #1, and another says to install at 10 degrees BTDC with the distributor pointing to # 1.
Would especially like to hear from Franklin or ctubutis as both have never steered me wrong.
Thanks!!
Last edited by sgauvry; 07-29-2015 at 06:53 AM. Reason: added a 1 after the # sign - changed neither to never
Old 07-29-2015, 08:49 AM
ctubutis's Avatar
ctubutis
ctubutis is online now
I'm thinking all three methods you're seeing are all leading to the same goal and are just different approaches to getting there, but of course people could be describing how to get to different end goals that I'm not aware of, too.
In the end, you want the rotor pointing directly at #1 with the timing adjusted to ~10° BTDC...
As you insert the distributor into the block, the shaft & rotor is going to rotate several degrees I believe counterclockwise, and that might be the reason for a one-tooth-off description. You will need a timing light to adjust the ignition timing once its running, typical setting is around 10° BTDC.
Your third, 10° BTDC description is a method in which you don't need to adjust the ignition timing afterwards... you orient the harmonic balancer so the pointer indicates 10° BTDC and then install the distributor with the rotor pointing directly at #1.
I hope this all makes sense....
Old 07-29-2015, 12:00 PM
sgauvry's Avatar
sgauvry
sgauvry is offline
Thanks! I know some folks like to advance or retard their timing based upon what goals they are after.
I'm planning to set the balance wheel to 0 degrees TDC and have my distributor pointing directly to #1 - keeping it simple.
Thanks again, Franklin, for coming through!!
Old 07-29-2015, 02:51 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,660 Likes on 1,342 Posts
That was Chris, not me. But my answer is just get it in the ballpark so it will run. You always have to put a timing light on it afterward to tweak it in. I supposed you know about the spout connector and setting the timing with a light?
Old 07-29-2015, 03:20 PM
ctubutis's Avatar
ctubutis
I was gonna be a smartass and say something like:
I'll be sure to tell Franklin when he stops by
But never did it for some reason.
Old 07-29-2015, 05:28 PM
sgauvry's Avatar
sgauvry
sgauvry is offline
lol! Sorry to you both!! Please let me blame my old age. I'm 60 in a few weeks, but my mind acts like it's 80.
Thanks for all you both do on this forum!!
rlh68050
08-17-2019 06:19 PM
RocketmanVT
12-30-2012 05:04 PM
part timing
07-31-2012 12:39 PM
Redone
07-31-2003 02:04 PM
jwxb41b
04-11-2002 09:12 PM
Quick Reply: Installing a distributor
