4R100 rebuild, 2600 ouch....what trans cooler to go with?
Hey guys i dropped my truck off yesterday at a trans shop, whom I trust it is owned by a close friends dad. We were hoping it was just the torque converter, but he said with all the metal he found in the pan, that if it were his truck he would rebuild the whole thing.
W 184,000 miles i figure thats likely true.
Anyway, the 2600, which i hope is a fair price, includes an HD torque converter, and mostly borg warner components throughout as i understand.
Also includes a new external trans cooler. I asked him if i could pick up a trans cooler and drop it off as i think he was near 300 for an oem style replacement. He said that would be fine. The 6.0 cooler is more than i want to spend, i dont tow often so cant justify it. But i was leaning towards one from Oreilly, the Hayden Ultra cool part #405...it measures 10 x 15 7/8 x 3/4. It is tube and fin design which i want. Is that any improvement over factory? I even thought about buying 2 and having him hook them up in sequence unless that would be to much cooling.
Thoughts? Suggestions?
Currently St.louis area, moving to san antonio area.
I dont tow really, occasionally a pontoon boat for a friend. But I will be purchasing/ pulling an enclosed from stl to san antonio. Likely 26 foot or bigger w all my stuff in it.
Truck has edge evo set to factory settings, 4" turbo back exhaust, PO pulled something as it has a gooseneck in the bed.
If you mean to add another cooler to an existing air to oil cooler resulting in 2 air to oil coolers and a radiator cooler that is not recommended due to potential loss of flow. If you mean to add an air to oil cooler to an existing radiator cooler then yes definitely.
All of these trucks have a factory oil to air cooler. Some have an oil-to-water cooler.
Yes he is replacing the factory oil to air cooler, said he can flush the radiator cooler out, but due to the design of the oil to air cooler it can not be flushed. This is where tube/fin design is advantage as it can be flushed, due to the little radiator style end tanks on the factory style cooler it will hold any particles inside those ends.
I did not know the design of the factory cooler had changed....
SORRY.
Aftermarket is best ... THEN.
do they still call the NON-tube and fin... Manifold type?
So, in the cold weather.. the engine Heat is not needed to quickly warm up the transmission fluid.
SORRY.
Last edited by Chuck's First Ford; 07-30-2015 at 04:23 AM. Reason: Engine Warm up.
Installing an improper cooler will make this far more likely. Do you really want to save the cost of replacing the transmission cooler in the event of a repeat failure at the expense of another rebuild?
I've seen them most commonly referred to as "stacked plate" type.
I'll go one step further. The cooler in the radiator is NEVER used to warm the ATF in ANY condition. I've tested it in extreme cold, extreme heat, loaded, unloaded, and never found a condition where it was even close. The ATF is ALWAYS warmer than the coolant in the cold side of the radiator.
