Mid fifties new dropped axle
Has anyone seen or used Mid Fifties new and improved dropped axle? I spoke to a sales person on the phone today but all she could tell me is they are using better steel. The price went up to $495. I called Nostalgia Sid after some members on this forum recommended it. I want to thank all of you becasue after reading all of AXracer's posts regarding straight axles and talking to Sid, I'm convinced a dropped straight axle is right for me. Sid patiently explained how to properly set up a dropped straight axle suspension. The unfortunate thing is Sid is behind 8 weeks due to the amount of work he has and relocating his shop.
Why would they admit something like that? I'm sure it is a case where the sales lady doesn't have a clue, tootsie rolls will make it all better I said that for you Jimmy
You would have good reasons to be wary of the old ones, of many different brands. Many threads on the HAMB about Speedway and Magnum axles with cast iron ends (the dropped sections) failing catastrophically. There's a reason Sid is busy... He's not the only one stretching stock forged steel axles, tho.
I'm clueless why MF person would have said that? That's not like them.
FWIU the issues with the 3 piece drop axles in the past is that they warped and twisted when the ends were welded into the main tube, and then were not sufficiently checked or corrected so the ends were not in perfect alignment with each other, with the spring perches in the shipped axles. MF was simply the distributor, not the manufacturer of these axles, and had no way or reason to check them after arrival. The manufacturer fell down.
Sid's the man! Send him your axle right away, it's worth the wait and 8 weeks will go by quicker than you now imagine. Gary's axle is a thing of beauty, you cannot tell it was ever modified.
Here is what the website says about it...
THIS ONE MORE EXPENSIVE, BUT GUARANTEED!!!!
NEW AND IMPROVED!!! new axle is heaver, nicer, made from highest quality steel, AND accepts 57-60 springs as well. ALSO available POWDER COATED, SEE 2890-BLK
It doesn't say anything about BETTER steel, only that it is 'heavier' and 'nicer'.
From the 2011 and 2012 catalog..
"There are two Dropped axles on the market, we carry both of course, best one shown here. We suggest better one for any truck with heavy engine, all Panels, etc."
2012 was the last year that they listed the cheaper one in the catalog.
Well AXracer....... we just haveto disagree about that one.........
