Duraspark module differences
My truck has a junkyard Duraspark ignition setup on it that's been in service for about a year. I bought it from someone else so I don't know what year the FE truck it came from but I know it came from a Dentside truck. I'm using the "blue" grommet module. I decided to replace the module with a Motorcraft unit and keep the junkyard module for a spare. To my surprise the ignition would not fire with a brand new module. I went to the parts store and got a new module, tested it there, put it on the truck and still no ignition. I put the junkyard module back on and the truck fires right up.
Both of the "new" modules are for a 1978 Ford F250 with a 460 and both are the "blue" grommet units.
I've checked the connectors and all wire colors are in the same place.
I'm stumped.
Is there some difference between "blue" grommet modules?
I'm stumped.
I'm stumped.
I'm stumped.
The 3 step scenario of a failing DuraSpark ignition module:
1) Module overheats, engine dies. Module cools down, engine restarts almost at once.
2) Module overheats, engine dies. Module cools down, engine restarts in a hour or so.
3) Sooner or later...usually sooner, the module overheats, BURNS OUT. Now the engine will not restart.
Engine heat, especially on V8's, is the mortal enemy of these modules that are located on the left fender inner apron, directly across from the V8's red hot exhaust manifold.
If replacing, use some washer to space the module further away from the apron, the more airflow, the better.
Taking the module to an auto parts store to be tested: Will test OK unless it has burned out.
1U2Z-12A199-AA (replaced D6AZ-12A199-A & B ~ D8VZ-12A199-A ~ D9VZ-12A199-A) .. DuraSpark Ignition Module - blue grommet (Motorcraft DY-893) / Available from Ford & auto parts stores.
Applications: Myriad 1976/90's FoMoCo vehicles.
D4PZ-12A112-A .. Stator aka magnetic pick-up coil (Motorcraft DU-1A) / Available from Ford & auto parts stores.
Applications: ALL 1974/79 V8 FoMoCo vehicles except 1979 LTD/Grand Marquis 351W with EEC (on board computer).
Most Ford techs replaced both of these parts, because the stator can suffer the same symptoms as the module.
I've seen a lot of them on vehicles in Arizona.
The fact that the Red grommet modules were intended for smog vehicles in Kalifornia explains the difference in advance curves.
Factory blue modules have two circuits, a start retard circuit and a run circuit. The system runs on the retard circuit when the starter is engaged then swaps to the run circuit when you let the key fall back to run. Lots of aftermarket modules delete the start retard circuit and only have the single circuit inside.
It sounds like maybe who ever wired your truck has it running on the retard circuit, maybe the wires are crossed? On the two wire plug that supplies power to the box, one is Start and the other is Run. You can try swapping them.
CharlieXLT
44
03-08-2018 02:04 PM
Sw1tchfoot
27
12-11-2012 09:21 PM
jdon88
02-16-2004 07:09 AM
GammaDriver
07-08-2002 08:51 PM
