Back Again!
Back Again!
So I changed out the Exhaust Manifolds on my truck! What a job! Took me a week by myself to do them. I tell ya those bolts were horrible! I have pictures to show talk If I can post them on here? Well anyways, I have a problem the truck starts shaking at around 30-35 and around 55-65. It does it all the time and last time i checked I had a 411 code. When I press on the gas it shakes and hesitates and doesn't wanna go anywhere. I have to let off the pedal and push on it slowly and its ok sometimes it still just shakes. Ugh! Help please! I love j Is forum and yalls advice. Oh yeah 92 Ford F-150 5.0 (302) 4x4. I have not done a tune up yet. Fairly new injectors and haven't messed with any sensors. I have unplugged the IAC sensor and it dropped down to 500 RPMs. Plugged it back in and it went back up some. So I guess that's working?
I checked the vacumm hoses but no leaks. I do have a leak in the vacumm reservoir but that wouldn't affect it like it is. It's just got emissions. Could it be the Idle Air Control sensor? Or some other sensor? It saids low rpm fault with Key on engine runnin test. Code 411. I will do another check engine light and get the codes and post them.
Also I remember a trick with the egr, as long as you don't unhook the solenoids it shouldn't throw a code, I blocked one off with a penny and didn't have an issue.
Also a 02 sensor could cause the egr code and vise versa
IIRC the coffee can (tomato can) is linked to the egr so possibly its been awhile since I owned one lol.
Junkyard here I come! Hopefully this fixes it. The EGR valve does look like the original one. What's the life span on those by chance? I don't wanna change it there $85 bucks so let's hope that can does the trick! The 02 sensor I seen to buy was Bosch I heard they suck on older vehicles is that true?
Good idea! I will have to take a few. They can't charge but so much for them since it's a junk yard. I'm guessing 15-20 bucks?
