1992 F150 with the 5.0 new autolite platinum plugs and oem wires. Rides smooth at higher Roma and shakes at stoplight etc.. almost feels like a misweighted flywheel or something with the vents I've heard but dint know much about. Any help is great thanks.
Oem wires that the owner before me had bought at oreilys. The platinum plugs were recommended ny my brother who is a certified Ford mechanic through NASCAR technical institute. I will check the firing order tonight when I get home because I'm at work right now
So how many miles or years on them?
Most of the folks teaching those classes were probably not born when these trucks were manufactured. Many on this forum have had the best experience with plain ol' copper plugs.
Great idea. There should be a sticker under the hood with the correct firing order.
Alright. I'll do that when I check the firing order tonight. But wouldn't all this make the motor shake more than the transmission? It's right below the hump and my 4wd shifter shakes like crazy so I know out has to be transmission related to some degree.
Regular Motorcraft or Autolite Copper core plugs is all that is needed for this vintage truck and using anything other can give you problems.
+1 on this all I run on mine is regular motorcrafts. I had a issue with e3 diamond fire plugs on a Mitsubishi replacing stock ngk platinums. missed so bad and shaked that it stalled more than once. E3s came out saturated with fuel. Put new ngk plugs in and ran great. Learned my lesson. Unless it's TRULY a built motor( in general) than stock oe replacements are fine.
Edit: that car was doing the same thing you described with the shake at idle. Pull a plug to see if its wet. Could be a incorrect gap or heat range
