1948 F-1 Shop Truck "ANN"
Thanks , I'll check out what you made. Just want to see a good way to support the cab and be able to roll it around
a Lincoln. Haven't actually run it yet, but it does turn over. Hasn't been driven or run since around 1991, has been parked in a pole building. Same with the red F-1 that was behind it.
Ok.. Started pulling the cab.
Found an issue with my plan, halfway through. The bed had to come off first, because to pull the cab with the steering intact I had to move the chassis forward, and couldn't do that with the bed there. So I rigged up a way to quickly lift the bed off.
Next fininshed lifting the cab up and found a way to secure it to the dolly I made. Frame is in better shape than I hoped. Bed is in worse shape than I thought.
Yesterday did some work on the frame. Pulled the old 6-cyl. and trans, started taking the old suspension off.
Wow, I never realized how much these frames flex! Definitely going to add some reinforcement and box this one in.
Going to finish stripping everything I don't need off of it, to get to the point where I'm ready to mock up the IFS and 4-link.
Dismantling continues
Working on stripping the frame still. Hoping I didn't jump the gun because after all this I realized I probably should have plumbed measurements for the centerline of the front and rear axles. Maybe not?
The suspension set-up I purchased is from Full-Tilt Hot Rods and I got about half of the stuff today but unfortunately not the Box with the instructions in it.
Anyways, added some cross bracing to the frame, so nothing moves.
Pressure washed some of the stuff and cleaned up the cab. Removed the gas tank from the inside. The cab is hurting bad on the bottom drivers side footwell area, to the point where enough support is gone that that side of the cab is sagging. So I am going to need to design something to tack it into place so I can remove the doors and replace the floor board.
No progress in a while been working on my project Audi. But i did salvage a donor car for the truck's drivetrain.
and got some parts...
Frame back from being sandblasted.
Parts car will supply the engine and rear end.
Doews anyone know how to identify the engine that's in this car? It's a '66 T-Bird and according to the VIN I think it should have a hipo 390. I know from looking at it its an FE based engine. Beyond that I know very little about these engines and V8's in general.
You mentioned the donor would give the engine and rear end. Any reason why you wouldn't use the C6 auto trans with it?
Oh, and if you're parting out the rest of the 'bird, there may be some pieces I can use. I have a 64 resto going, among my many projects.
#29
#30
Sent you a PM but If anyone else is curious I have more of these T-birds that I was going to sell as parts cars. A few I have titles for, varying condition. I dont have any clue as to the value of a 64-66 Tbird with a straight body but if anyone is looking for a project I have a couple.
Dazzle
22
06-10-2018 05:07 PM
ktgovols
71
02-20-2018 09:46 PM
55ClubRunner
15
10-11-2016 05:41 AM
chickenwings_85
27
09-09-2014 07:15 PM
