Our first trip! New RV
We took our new Vibe 308 out and had a blast this weekend!!! Here are a few pictures. We went to Kingsville, Tx and stayed at a new RV Park that was really really nice! AC had a real problem keeping up with the 104 degrees temp but when the sun went down, it would freeze us out. Tint and window blocks are our next mod.
Looks like a great time. Go to Home Depot or Lowes, in the insulation isle there are rolls of a foil bubble wrap like material. Pick up a roll and cut the proper side to insert into the windows of the RV. Insulates the window as well as reflects the heat of the sun. You will be surprised what a temp difference it will make.
Of course there is also the option of a second A/C unit. They slip very well into the 14x14 inch vent in the bedroom. Then run a cord to a basement storage area that you can plug in to the pedestal 20amp service receptacle.
Or parking under a tree also helps....LOL Not always an option in Texas
Like others have said, it looks like a great time. I agree with Scott that a 2nd AC unit would do wonders, but also agree on the Reflectix. If you can't find it, WalMart carries rolls of regular bubble wrap. The smaller bubbles work better than the larger ones, but mist the window with water and stick it to it. You'd be amazed at how much of a difference it makes. We use it all winter here to insulate the windows on our 5er. The reason we don't buy it at Home Depot is that is they only sell it in a green color. WM sells it in clear which looks much better.
Justin, that's a great way to break in the new RV. Looks like you guys had fun. I too had an issue with Texas heat. One of my problems was the factory unit was a 13,500 btu. I bought and installed a 15,000 btu unit in its place. I wanted to reinstall the 13,500 in my bedroom, but between the kit to convert from ducted to ductless, and the wiring and installation (I would have to hire help), I couldn't swing it. I did install the solar shields as others have mentioned. Between the new unit and the shields in the windows, I can stay reasonably comfortable when the outside temps are high.
Do you happen to still have the 12,500 unit? Willing to part with it?
The 13.5k is in Oklahoma with my parents and brother. I don't know what - if anything - they have done with it. They had talked about putting it to use on a FEMA trailer that they used to have, but sold last year. If you are still interested, I can check, but shipping would probably make it unpractical price wise.
