'63 F-100 wiring problem
Sorry if this is confusing but I"m trying to get used to this whole forum thing. So my '61 works fine except for my driver side turn signal, and it only acts up when i use the brakes or have my lights on. Basically it'll work fine when no other lights are in use on the driver side, but the moment you turn headlights, park lights, or step on the brake the driver side turn signal sticks on. Not flashing or anything it just lights up and stays on and my turn signal will no longer flash. I'm relatively competent with cars but I'm not so great with wiring so I'd appreciate some help
C3TZ-13341-B .. T/S Switch / Obsolete
Applications: 1963/64 F100/250 2WD
FEYER FORD in Edenton NC has 1 = 252-482-2144.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
No other Ford dealer or obsolete parts vendor has any.
x2. I had a similar issue recently with my emergency flashers. After spending hours tracing all my wiring it ended up being a bad ground.
Chess67
13
06-28-2018 11:29 AM
skidmarks
07-07-2004 11:04 PM
