My speedometer is not working on 2005 excursion,Engine light on, abs light on and overdrive blinking - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Log In
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-26-2015, 12:02 PM
Aminmir Aminmir is offline
Aminmir is starting off with a positive reputation.
Hi
I have 2005 ford excursion with 24300 miles. My speedometer is not working, engine light on , abs light one, overdrive flashing. I just changed speed sensor on rearend, but my speedometer still not working.
Need to know how to fix.
Thanks
Old 07-26-2015, 12:32 PM
mecdac's Avatar
mecdac mecdac is offline
Thread Killer
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Take a look at:
http://www.ford-trucks.com/forums/13...inking-od.html
or
http://www.ford-trucks.com/forums/98...esnt-work.html
or
http://www.ford-trucks.com/forums/74...goes-nuts.html
See if any of the above is helpful.
__________________
Mark
The first casualty in every war, truth.
(Rudolph)
http://vimeo.com/user25371657
Old 07-26-2015, 10:00 PM
Krazee Matt's Avatar
Krazee Matt Krazee Matt is offline
Leadfoot
Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.Krazee Matt has a spectacular reputation.
Krazee Matt
Did everything but the speedometer get fixed with the new VSS?
When mine had the same symptoms it ended up being the ABS module computer.
__________________
Stay Puft: 2001 Excursion 7.3 Lmtd 4x4 / 6637 / 4" turbo back, 5" tips / Gearhead 6-pos / 238/80 sticks / RR FRx, HPX, tri-pillar gauges / V & 2" hangars, B-mod, Bilsteins / 315/75/16's
Cecelia: 1971 Chevelle / under the knife, again. Built SBC coming out, built and forged 513ci BB coming in. Goal = 730-770rwhp through built manual VB 4L80
Old 07-27-2015, 07:27 AM
I have changed vss , but not working.
Old 07-27-2015, 12:04 PM
Leadfoot
Krazee Matt
What codes are you getting from the CEL?
__________________
Similar Threads
1992 F150 speedometer not working. KaiserKlauss 1987 - 1996 F150 & Larger F-Series Trucks 0 06-16-2015 06:02 PM
ABS light, overdrive light flashing, speedometer jerky bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 20 11-08-2014 04:59 PM
1996 F-250 4x4 Speedometer...PSOM?? lindboep 1987 - 1996 F150 & Larger F-Series Trucks 10 08-25-2012 03:32 PM
2000 Excursion flashing OD light and Beeps derekmj64 1999 - 2003 7.3L Power Stroke Diesel 6 05-28-2012 08:01 AM
Speedometer does not work and ABS light on jonnyrocket_70 Ranger & B-Series 14 08-21-2004 06:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
