timing cover seal - Ford Truck Enthusiasts Forums
timing cover seal
Old 07-31-2003, 07:00 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
timing cover seal
when ford designed the timing cover seal why did'nt they make it to go in from the outside??
i had to replace mine on my fresh rebuild (somehow it got ripped) and in order to change the seal it requires pulling the whole T/C off!
Old 07-31-2003, 11:50 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
timing cover seal
You can save yourself some time now if you still have the cover off. Just cut the lip off that the "old" seal presses up against and use a newer timing cover seal. The new covers allow for installation of the seal after the harmonic balancer is removed. Just FYI.
Old 08-01-2003, 01:07 AM
Hired Gun's Avatar
Hired Gun Hired Gun is offline
Hired Gun is starting off with a positive reputation.
timing cover seal
My 1987 460 seal went in from the front. The newer covers are available on Ebay brand new for 75-80 bucks.
Old 08-02-2003, 07:14 AM
timing cover seal
thanks airharley, got it all back together tho already but will do that next time
Old 08-03-2003, 12:39 AM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
timing cover seal
I changed my timing chain and gears today, boy was there some slack! I would change them while you are that far. Carefully pry the thin metal away from the timing cover all the way around the seal and it should pop out.
Old 08-03-2003, 09:18 AM
78 460 5 speed 78 460 5 speed is offline
78 460 5 speed is starting off with a positive reputation.
timing cover seal
I have a 79 mode timing cover that has rusted out. Can I get one off of newer truck like a 89?
Old 08-03-2003, 09:36 AM
timing cover seal
c rossman, i would change the gears but it was a fresh rebuild, somehow the seal got tore putting it in the sleeve? don't know how that happened but it is all done now
78 460 i think the timing cover's are all interchangeable
Old 08-03-2003, 04:13 PM
ludis ludis is offline
ludis is starting off with a positive reputation.
timing cover seal
They aren't quite interchangeable. The newer covers can't take a dipstick. If you were to try drilling a hole for the dipstick, you'd hit a water passage. Ford does/did have a service part for the older trucks that takes the front installed seal.
1986 5.0 Timing Cover Seal DGMFORD Performance & General Engine Building 0 04-04-2015 11:46 AM
replace timing cover crank seal without removing cover? General Geoff 1987 - 1996 F150 & Larger F-Series Trucks 2 12-28-2014 01:39 PM
Changing 92 4.0 timing cover seal 1998Ranger25L153CID Ranger & B-Series 1 10-06-2014 02:09 PM
seal at tranny schoo 1961 - 1966 F-100 & Larger F-Series Trucks 18 09-19-2014 12:10 PM
front cover replacment tips bigcrunch 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 03-24-2014 08:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
