Battery? ...or something else?
Went for a ride today, about 60 miles, truck was running well. We stopped for breakfast and when we came out the truck took a little longer to start than usual, just a few seconds. Going down the road I noticed the battery gauge was showing high charging rate, after a few miles it went back to almost normal.
It is 6 volt positive ground, battery is a Optima and is 54 months old.
Any thoughts?
Ed
near Philadelphia
Any thoughts?
Ed
near Philadelphia
Usually the voltage regulator is the culprit for overcharging. It can smoke your battery too. I'd clean up the terminals like mentioned above, and put an actual voltmeter on it. If it is intermittent wire the meter to the battery and tape it to the windshield. See if it is actually over charging at times.
Possibly the battery was low on charge, causing the slow start and then the need for higher than normal charging. Battery is almost 5 years old, it could be near end of life and unless you have an electrical drain problem I would be keeping an eye on the battery voltage before it leaves you stranded.
Fordf348
You need to get a multimeter (DMM)/voltmeter on the batter as soon as you can. You need to make sure that you have a full charge on the battery. Turn the headlights on for 1 minute and then turn them off. Take another voltage reading. This will help determine if the cells are holding a surface charge (battery thinks its full but as soon as you apply a load it drains) or it will help show a good/bad battery depending on voltage after the test. You can also take the battery to any Autozone and have them load test it. Make sure it is fully charged first.
If there is and accessories left on that could have caused the slow crank/discharged battery demanding the charging system to work harder. It will show a high/long charge due to weak (or low current rated) alt/gen. High resistance on cable ends and grounds can mimic this as well. Clean all cable ends with a wire brush. The lead will go from dull grey to shiny silver. That is the lead oxidation that you are seeing get cleaned up. If you have any green furry cables/connectors/terminals then you need to wire brush them and clean with baking soda and water. This neutralizes the acids in the corrosion. Check all grounds (frame/firewall/engine block) clean all oil and rust (clean any paint from ground points as well)
I checked the truck this morning and put my multi meter on it(not a real good one)
it shows about 7 volts before start up and goes to about 9 volts when reving the motor.
So it appears to have cured itself, I need to take it for a ride and see if the problem persists when hot, I did order a new Optima battery at Amazon for $120, I will put that in when I get it. I also am going to order a new voltage regulator in case I need that, the one in there is about 15 years old.
Thanks for the help
Ed
Thanks for the help
Ed
I have the same issue.
When wires heat up, the resistance increases. That will be amplified by any weak spots in the charging/starting system. My next step is to replace the battery and ground cables(got them for free). I've replaced the starter which made a good difference, but still have a hard time starting hot. It seems just like a discharged battery.
Solid and clean connections,
battery/ground wires in good shape,
and starting components in good shape and I'd think you'd be rid of any problems.
I'm curious though. Can a starter solenoid cause hard starts? I'm wondering if the contacts inside can be corroded enough to provide continuity, but too much resistance.
