95 f350 steering twisting with Death Wobble
Old 07-26-2015, 12:30 AM
Willz74's Avatar
Willz74
Willz74 is offline
What is death wobbles none of my vehicles have ever had sway bars I've done over 100 in a truck whose tie rod that seemed to only have the top half of the ball and 70 in a truck with a ball joint split in two and I've never had anything happen that I would call death wobbles
Old 07-26-2015, 11:14 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
It's weird some trucks are more sensitive to it. Mine is due to my lift and tires. Jeeps are known for being the worse. And it's called death wobble because the truck violently steering left and right. So bad to were its hard to stop the truck and or steer the truck
Old 07-26-2015, 11:17 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Oh and update. I did finally find something I noticed the track bar mouts slightly move back and forth from the axle. So I took it off and she had a quarter of a inch gap. So lets see what happens
Old 07-26-2015, 11:57 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Great find.
Old 07-26-2015, 01:10 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Yyyaaa thank god it fixed it thanks for the input. It's my tow rig and daily driver so I needed her back on the road. And I'll put some stabilizers on to help buffer that wobble if it start up again down the road
Old 07-26-2015, 08:13 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
She's a little loose but not bad.
1/4" gap! Holy crap! Glad you got it fixed.
Old 07-26-2015, 09:21 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Hah wellll it looked only a little loose while it was bolted up. But then when I took it out I found it moving. It was actually still in good shape. It was my oil leak dripping on it and made the rubber get soft. So I got some Moog polyurethane
ablack350
1999 to 2016 Super Duty
06-24-2018 11:27 PM
greentree ford
12-07-2012 10:44 AM
sboorse
09-04-2012 08:40 AM
realbigtruck
02-07-2001 03:41 PM
Quick Reply: 95 f350 steering twisting with Death Wobble
