95 f350 steering twisting with Death Wobble
Old 07-25-2015, 12:06 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
On my truck every thing was fine untell she started giving me really bad death wobble at 35 mph. Didnt hit a bump or anything. So i limped it home and had my girl turn the wheel back and forth and the linkage was twisting as she turned it left and right. The truck is lifted on 37. I think i need a new tie rod. But is there a better fix for this ? and am i looking in the right spot
https://goo.gl/photos/pwY9QKDy7fumXjRC7
^^heres video ^^^^^^^
Old 07-25-2015, 12:11 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Think this is the bad joint.
Old 07-25-2015, 10:19 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
?? anything
Old 07-25-2015, 10:52 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,163 Likes on 918 Posts
My old '92 F350 had very loose steering like that until I replaced all the tie-rods and links. Problem was solved. I distinctly remember seeing the link in question "roll" when turning the wheel from side to side before I replaced it.
Old 07-25-2015, 11:13 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
yeah thats the weird thing is that they are all tight front left and right. its just twisting everything. But the one tie rod with the red arrow i pulled off and its a little loose when i move it a certain way. Im going to replace it and see what thatll do
Old 07-25-2015, 02:30 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Google "tie rod roll", you'll find a lot. Mine has it too and I suspect all OBS F350s (and F250s that had been converted to a D60) have this.
The drag link from the pitman arm connects to the front of the tie rod. So, as the drag link pushes and pulls left and right, it also lifts and lowers the tie rod. Lift the truck and this is exaggerated.
Other than redesigning the steering, rotate each end of the tie rod (at the wheels) the opposite direction so they 'lock' against each other. I leave a few degrees of slop as the wheels don't steer perfectly in line with each other.
About the death wobble….do you have a track bar installed? If not, why not? (Not scolding, just asking.)
Old 07-25-2015, 02:44 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok I see what ur saying I'll try that. Because it never did it before untell after I replaced my steering box. And yes I do have one. She's a little loose but not bad. I just replaced the drag link and she still twists. Not as bad tho but still wobbles. I'll try your idea tho right now I'm in the shop working on it. Thanks
Old 07-25-2015, 04:22 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok I put the tie rods in opposites from each other and that made the linkage roll stop but I still have really bad wabble. It also seems to hope too when it Dos its death wabble
Old 07-25-2015, 04:41 PM
rla2005's Avatar
rla2005
If the other tie-rods are the same age then they should be replaced too IMHO.
Old 07-25-2015, 04:45 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Rotate the tires front to back and see if that helps. A broken belt in a tire does strange things. And by the way, a track bar that is even a little loose is too loose!
Old 07-25-2015, 05:02 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Ok I'll check it out some more. And the tires seem even. I spun them around a few times and didn't see or feel any out of roundness ? It feels like death wobble wile running over wash boards in the front end. And it's really hard to stop the truck when its doing it. Just tryn to give more clues to the puzzle cus everything is tight and straight
Old 07-25-2015, 05:40 PM
rla2005's Avatar
rla2005
How do the spring bushings and track bar bushings look? Another source of death wobble.
Old 07-25-2015, 09:26 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
They all seem fine. I'm really at a lose I'll post a video
Old 07-25-2015, 09:45 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
https://goo.gl/photos/SKBm3unMoqqcM8EW8
Ok here's the front side. I can't get the video of the back part to load with the track bar
Old 07-25-2015, 09:50 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
https://goo.gl/photos/rZvo64TSGh8MNtgy6
Let me know if they load. Here's the track bar. Now the track bar mount did seem to move a little bit from the axle
Quick Reply: 95 f350 steering twisting with Death Wobble
