TPS or IVS??? That is the question!
Okay, 2002 F350, 7.3L 180ish miles on it so it is just getting broken in. For the last year or so, we have had what I thought was an issue with the accelerator where it seemed to have about 2 inches of travel before I would see any acceleration. I even asked a lot of people about this and got the feeling that this was normal so I just lived with it. So I am currently on a trip with it and towing our 5th wheel and we are about 10 hours from home but on this trip I am seeing a problem. It has happened about 5 times now where when I push on the pedal, I get NOTHING! I let off and push on it again and it is "normal" again. The engine idles fine, I don't get any CEL. This happens with and without trailer so I believe that can be taken out of the equation. So what says the brain trust here?
Heading back home on Sunday and O'Reily's has a TPS in stock for $33.00. Would it just behoove me to just get it and do a quick change out or do I need to be looking at something else? There is no way I can get the whole assembly here in time for the drive home which is very pricey since we have the adjustable pedals, but I certainly do not want to have it go completely South in the middle of the trip home.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
The other is the IVS (Idle Validation Switch) is either On/Off.
So, its the AP (or what you're referring to as a TPS (which, is attached to a Throttle Body))
I don't know as the possibilities of changing the AP Unit on 2002. But, will look it up in the am.
What you're referring to is the AP (Accelerator Position) These are basically a Potentiometer where resistance is decreased, current is increased, and a signal is sent.
So here is another question. I do have the adjustable pedals and boy does that make the cost go on changing out the whole assembly. Would the "non-adjustable" pedal work in a pinch if I can get my hands on one while out here on the road or will the mounts be different? Just trying to cover my basis if something were to happen.
David, I live in Colorado but currently in Nebraska.
You can pull the plug and put a meter on the contacts to the TPS (one probe in the middle, one on either end. Set the meter to Ohms and very slowly move the TPS. Repeat the process with the outside probe moved to the opposite end, keeping the center probe in place.
If the Ohms rise/fall steadily, that's all you can ask from the TPS. If it jumps or drops in places, then recovers - try cleaning the TPS and test to ensure this is a fix.
If this were on my truck, I would grab an OBDII scan tool and log the TPS voltage while I very slowly move the throttle in and out. I would then look at the log on a graph, in search of spikes/drop-offs.
jstihl
12-23-2017 08:18 PM
