Rebuilding a "rebuilt" 351W (pic heavy)
Old 07-24-2015, 08:10 PM
sengel1975's Avatar
sengel1975
sengel1975 is offline
After a lot of thoughts, more research and readings on this side (thanks all for sharing your knowledge and experiences), I jumped forward and bought a "rebuild" 351W as a replacement.
I´m having a 1982 Ford F100 Shortbed Flareside, that came originally with a 255 V8. Not been taken good care of, the PO`s left me no choice then to replace the tired little engine.
Started a thread, looked into crate engines and then.... made the decision to buy a "rebuild" 351W from a guy in the area.
The 351W came originally out of 1984 car, and was fresh rebuild. The seller had sandblasted the block, but not painted it. He was not sure, which color to choose, as the Mustang was not painted either the engine was planned for. This project died, he sold the Mustang and was now offering the engine.
I saw the video of it being on a engine stand, running. Here´s the story of light and shadow. enjoy and I look forward to your feedback..
Old 07-24-2015, 08:13 PM
sengel1975's Avatar
sengel1975
The buy...
Here are the pics of the engine from the ad... The carb was already sold, everything else included
Old 07-24-2015, 08:20 PM
sengel1975's Avatar
sengel1975
first deep look at home...
When I got it home, I brought to the shop i can work on it. Put it on a engine stand and took off that ugly, rusty waterpump.
The oil pan was ugly, so to repaint it, we drained the oil and took the pan off..
without the intake..
oil pump and extender. In the oil pan was a lot of grease and old oil:??????
That´s the provision for the oil dipstick. For the cars, it came through the block instead the oil pan. Some I... had pushed a screw in and filled it with what locked like sealer.....
The Edelbrock performer intake was unfortunately without EGR. As I´ll move to NY State next year, I need to take all the emission stuff on it- bye bye and hello new Intake w EGR...
Old 07-24-2015, 08:32 PM
sengel1975's Avatar
sengel1975
Good news, bad news...
After taking apart, I found as follows:
- Machine work was done good. Pistons, everythin looked as it should be.
- in the reassembly, the I... somehow decided to fill the engine with old, greasy oil. Bad News.
- Good News: the engine seem only to run one time on the dyno, so only the main bearings were affected and had to be changed. Everything else looked good. Bearings were -20, new ones cost around 60,- $.
you can see the copper coloured stretch, where grease made some damage. Would not have lasted long...
Old 07-24-2015, 08:38 PM
sengel1975's Avatar
sengel1975
cleaning and painting the block..
Took the empty block, pressure washed it and then took everything into the paint booth for prep and paint. Used the POR15 engine paint kit. Decided to go with silver (look out for my resto thread of my truck and sometime you might agree with that choice).
ready for the pressure washer...
primer on it...
and with the final color...
painted also the heads....
...and with high temp paint the exhaust manifolds..
Old 07-24-2015, 08:41 PM
sengel1975's Avatar
sengel1975
little bit of progress...
adressed the wrong filled Oil dipstick provision. Cut a thread into it, plugged it and put some thread locker on it...
of course done, before starting to paint...
The Plug from the outside...
And from the inside...
Old 07-24-2015, 08:48 PM
sengel1975's Avatar
sengel1975
Start to reassemble....
Starting to put everythin back together....
new bearings and the cam already in it. I kept the stock on in it, it´s going to be a cruiser, nothing crazy...
With the heads back on... I know, should not have painted the inside... I removed that paint later, what a pain. But my experience gained...
the oooold timing cover didn´t looked nice enough, Let´s get a new one... (one bolt broke, and this little ******* killed my removal tool...)
Had to put a new timing set on it, the old one was a little loose.
Old 07-24-2015, 08:50 PM
sengel1975's Avatar
sengel1975
the oil pan...
decided to keep th eold oil pan. Therefore, lets get rid of the old paint, clean it and paint it....
that´s how she came off...
thanks to my wirewheel....
Old 07-24-2015, 08:53 PM
sengel1975's Avatar
sengel1975
assembling the lower end....
After putting a new rear main seal and a new front seal in it was it time to finish the lower end. New oil pump and extender, and putting th erepainted oil pan on it...
Old 07-24-2015, 08:54 PM
sengel1975's Avatar
sengel1975
new parts on the shiny front end...
Had to buy a new harmonic balancer, th eold rusty on was pretty much done...
Old 07-24-2015, 09:01 PM
sengel1975's Avatar
sengel1975
current status and plans...
So guys, this is the adventure so far. I think, I was still lucky with the engine so far, and the total cost was still less than half of a crate. Hoping, that it will run also for good....
I´m waiting on the arrival of the new Air intake (edelbrock performer w EGR), I already have a new Edelbrock 600cfm 4bbl carb at home, new waterpump, timing indicator and nice pulleys.
Here is now the point, where I need support: I decided to stay with my Duraspark II ignition system, Have a new distributor and will keep my ignition coil. The biggest challenge: I have to put on all the emission stuff. So, while everyone is getting rid of his air pump and the smog system, I actually have to put it on. When I´m in the final stage of the assembly (this is my first engine btw...) I will need some serious help to get the vacuum and other stuff right..
So stay alert and thanks in advance for your comments and thoughts...
Old 07-24-2015, 09:21 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
If you get it in a running car before you move would it need to have all the emissions equipment intact or just pass the smog test?
What cam is in it? Biggest thing I'd change while it's apart!
Old 07-25-2015, 08:08 AM
sengel1975's Avatar
sengel1975
SDDL UP: for the emission stuff: I'm going back to Germany in a few years and want to take it back with me. To get a historic registration, it has to be Stocklike. I rather do all right once instead of starting over and over again. So, yes. I'll put all of the emissions stuff on it completely.
For the cam: the stock cam in it looked to good to throw away. My plan for the truck is as a cruiser, no towing, hauling, mudding or drag. Just want to enjoy it on the weekends.
Given my level of expertise, I'm happy to get it together right and there is a lot more to do on the truck. Will start a thread this weekend...
Lneidlinger
10-17-2016 11:29 AM
Fordbronco69
66
09-18-2016 02:55 AM
Crewcab Turbo
18
06-21-2013 01:21 PM
hivoltj
40
01-19-2012 07:12 PM
Forest_54_Ford
20
05-06-2010 06:50 PM
Quick Reply: Rebuilding a "rebuilt" 351W (pic heavy)
