Radiator & water pump replaced, flushed - STILL overheating
New thermostats can be bad, especially if you let the parts guy sell you one of those "fail-safe" ones. By the way, you did put the thermostat in the right way didn't you? Spring facing towards the engine. If you put it in backwards it won't sense temperature correctly and won't open.
Did this ever get fixed?
That was pretty good thinking by dixie460. Common enough to do. The "sensor" has to be on the correct side to work and it's easy to put the thermostat in backwards.
Did you ever try just removing the thermostat to see if it still overheats?
What makes you think the fan clutch is bad? If it overheats while driving at a decent speed, like around 40 mph or above, then I doubt it's your fan clutch.
The following users liked this post:
#29
This thread was started 6 months ago, so I'm sure his issue is resolved. Like a ton of threads, we will never know, because he didn't update. I read through, and just want to emphasize that you never run without a thermostat. This is a common mistake people make, and can actual cause an over heating problem. Running without a thermostat lets the water cycle through the radiator much quicker, not allowing it to have time to cool.
1986 f-150 4.9l AZ
07-22-2018 10:25 PM
austinrogers99
05-04-2015 11:04 AM
