7.3 block for rebuild??????
At some point between 1995 and 1999 (I think it was 1997, but not sure), there were some changes to the block and crankshaft. I don't believe the crankshaft and blocks can be mixed. There was also a change to the block over the lifters. The later blocks have added webs for stiffening that area. Having said that, I have a 1995 short block in my truck right now with late 1999 front cover, HPOP, fuel system induction system and heads. I did have to change the motor mounts from the block out, as they're completely different on the OBS trucks.
I probably don't know as much as the rest of you but swapping just the blocks should work fine.
A friend of mine who is a mechanic told me that the 97 has stronger connecting rods than the 02.
So what exactly is all changed on the block and heads I'm not sure. I put a 1997 engine in my 2002, leaving the heads on as well. Gotta change the fuel and air system over but just doing the block you shouldn't have a problem.
kbarbee95
08-18-2015 06:33 PM
Brians97F250Crew
02-16-2010 09:50 PM
tjhale
04-23-2000 11:12 AM
