Is my truck losing power, transmission going, or am I going crazy? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Log In
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Old 07-23-2015, 09:39 PM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
It is an 08 Supercab with the 5.4, 3.73, 58,000 miles. Truck has had NO issues until this point.
I used to be able to pull out and slip/squeel the tires (285-75-R17) if I wanted to. Now I can't, the truck just doesn't feel right.
I checked the transmission fluid (pan shows a little leakage, nothing major), it was a little low (still on the dip stick but not in the hot area). I thought that might be the problem. I added fluid, no help.
Cleaned the MAF sensor, no help......I don't think it is in the engine though, it revs fine in neutral. If I put it in D or 1st, and get on it hard from a dead stop it pulls hard to 2500rpm, then it bogs down from 2500-3500, at 3500 it takes back off pulling hard again ......Any ideas???
Oh, I did notice when I let off after revving it in neutral, I get some popping and cracking under the cab.....I didn't notice that before, maybe I overlooked it, is that normal?
Transmission fluid is good
No Codes
No engine Light
Clean MAF
__________________
1956 F100
Old 07-23-2015, 09:47 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is starting off with a positive reputation.
Possible restricted exhaust flow. Check tubing, cat converters and mufflers for damage or internal restriction.
__________________
2007 F-150 V6 5-Speed Manual
Old 07-24-2015, 01:14 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
How long has it been since the fuel filter has been changed?
Old 07-24-2015, 02:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
This is not a transmission problem. It's an engine problem.
__________________
Mark
Former Ford Automatic Transmission Engineer 1988 - 2007
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Old 07-24-2015, 03:12 PM
mjlewis's Avatar
mjlewis mjlewis is offline
mjlewis is starting off with a positive reputation.
go to autozone and have them do a diag on the truck, might have a bad plug or coil.
mine did the same thing... just didnt feel right and low power.
Diag said we had a bad plug or coil, so we replaced all 8. back to normal now.
thanks
__________________
Mike
Lilburn, GA
01 Ford Ranger Edge
04 F150 FX4 screw
Old 07-25-2015, 08:59 PM
OK,
Found part of it, maybe all.......
I forgot to mention I put a new fuel filter on it, that is not an issue.
We left on our way to the beach, I had to drive 100 miles in the WRONG direction for my daughters doctors appointment. So I drove the truck, 100 miles in, a grind started in the front end.
As we drove home the grind got louder, I did all your typical stuff....shifted into neutral, noise left. when coasting noise was gone. I pulled over, and crawled under it. I noticed the front axles were hot. One spun free the other wouldn't.
I drove it on home at this point and decided not to continue to the beach. I noticed when in 4wd the noise would quit. So I was sure it was there.
I took apart the front hub that was grinding (this axle spun free) the locker gear was ground down. So I pulled it out, I can drive the truck in 2wd for now.
I studied how the assembly worked, and realized that the hubs lock in and out. Something didn't set right with me. So I got on here and looked, I had been under the assumption this system worked as my 2000 model and all shafts turned to the diff. Not so. I noticed there was very little vacuum on this side, thought I had a hose issue.
So I got to thinking the other shaft should spin free which it wasn't. So I tore it down
and there was THE problem. There was a hole in the diaphragm, which had let water in and rusted out the housing. This side was locked in 4wd, and had been for some time.
I pulled the locker out of it for now as well. This relieved a vibration issue I had, and MPG's went from 12 up to 15on the highway. I am still not back to 17 where I once was. It is definitely a start though. The truck is still lugging in that 2500-3500 range.
__________________
1956 F100
Similar Threads
2001 f350 5.4... engine or trans? Tbaub627 Super Duty & Heavy Duty 6 03-04-2015 06:22 AM
transmission fluid jspence105 Excursion - King of SUVs 4 08-20-2014 06:06 AM
Totally stumped on transmission problem Vettedrmr 1987 - 1996 F150 & Larger F-Series Trucks 17 12-27-2013 09:42 PM
E4OD shifts hard -fixed- Prototypemech Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-24-2013 10:05 PM
96' E4OD Revs High, Shifts Hard, Searches for Gears? BDFD 1987 - 1996 F150 & Larger F-Series Trucks 8 08-21-2012 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
