E4OD questions (new owner)
Last week i picked up a 1991 F150 with a trasmission (E4OD) problem as a first vehicle for my 15 year old. The main problem turned out to be oil starvation from a caked filter.
The fluid wasn't burnt, but I've always heard about the dangers of replacing fluid that has been used as long as this had. I reused the same fluid after running it through a filter/funnel i picked up at TSC. I did not, however, drain the torque converter. I couldn't figure out how to refill it. Now I know....
Current symptoms: It drives fine in Drive. It will sometimes die when put into Reverse or Second gear. It always dies when put in First gear.
So, draning the TC. Yes or no?
Transmission flush?
Transmission treatments such as Lucas? Any other ideas?
Since this is the first A/T I've messed with, i have googled like crazy to get this far.
Thanks
David Shields
Transmission flush?
Thanks
David Shields
Yes.
Not if you flush the trans. If you don't flush the trans drain the torque converter AND the pan at the same time.
I sure wouldn't.
Thank you, Mark.
That's what i needed to know. Would a flush machine get the torque converter too? I know that Jiffy Lube has one, but I'm a little wary of inexperienced personnel. I have no problem draining and replacing the fluid myself. I just want it working right for my son.
David Shields
David Shields
on
I'd say run a can of Seafoam trans cleaner through it BEFORE draining the fluid again: Then do the full drain & replace of the fluids. BE SURE TO USE THE PROPER FLUID! The dipstick should state what type you need to use... Quantity will be listed in the Owner's Manual...
Personally, I do NOT trust the "flush" machines: they tend to blow out seals...
The torque convertor is VERY EASY to drain & refill, done when you drain the pan(and replace the filter, as well!) Simply remove the cover at the very bottom of the bell housing(round plug), and then use a breaker bar and socket on the crank pulley nut to turn the engine until the torque convertor drain plug appears in the center of the opening. Remove it, and let it drain completely. This will take a WHILE... Once drained, replace the drain plug & torque it properly, then replace the cover plug. The TC will refill from the transmission automatically.
Scott
Scott
The flush machines do change the fluid in the transmission and the torque converter.
I use this method to change transmission fluid: Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
on
I would NEVER do that. But that's just my opinion.
***Seafoam is fine.
The owner's manual is out of date. The correct fluid now is MERCON V.
***The manual IS still correct: The transmission was made to operate on one specific fluid, and the manual & dipstick will specify it. While a newer fluid CAN be used, using the correct original one is best for the transmission: Otherwise they would have pulled Dexron II/Mercon off the shelf when the new stuff came in.
No, that's not true. There is NO WAY one of these machines can blow out ANY seal. Anyone that says it can doesn't know how they work, or how an automatic transmission works, or both.
*** Used to work in the business: Improperly operated, YES, they do blow out seals and packings. And yes, I do know how they work, and how an automatic transmission works...
This will work. It doesn't change as much as a flush does, but it's a good method.
***Seafoam is fine.
I stand by my recommendations, but do as you like...
I feel the same.
And for your information, Ford *DID* discontinue MERCON. There are no longer ANY licensed MERCON fluids produced. There are fluids that say they are for transmissions that used to use MERCON. But Ford no longer issues licenses to produce MERCON. They do issue MERCON V licenses.
Does the fluid that says it is for for transmissions that used to use MERCON still meet the MERCON specification? Nobody knows, because nobody is monitoring that. Ford monitors all fluids that it licenses, and they don't license MERCON. So MERCON is no longer the correct fluid to use. If you use one of those fluids, and it does meet the now obsolete MERCON spec, all will be fine. If it doesn't, who knows what will happen?
I second what Mark said above 100%.
Never use any additive (band aid) in a transmission.
The other poster does not understand an E4OD.
As Mark said the manual is out dated. Use only MERCON V.
See this TSB:
http://www.stangnet.com/images/stori...s/06-14-04.pdf
See this TSB:
pbrogan
09-10-2015 05:46 PM
1994 f150 4x4
09-03-2013 08:49 AM
RIKIL
03-11-2012 12:15 PM
Skandocious
10-03-2006 12:56 AM
brandonconner
08-03-2006 09:18 AM
