Bed components availability for a 76 highboy - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 07-23-2015, 11:27 AM
mlacek mlacek is offline
mlacek is starting off with a positive reputation.
hey guys, I have a 76 highboy with a flatbed. How easy is it to get The body panels and components needed to convert it back to a regular bed?
Old 07-23-2015, 11:58 AM
bkaul's Avatar
bkaul bkaul is online now
bkaul is gaining momentum as a positive member of FTE.
There are 6 or 8 bolts that hold the bed to the frame - it just bolts right on. With a highboy having an in-cab tank, you wouldn't need to worry about hooking up a fuel filler tube unless you add an auxiliary tank. Would just be bolt it on and hook up the tail lights.
With a high boy, you have a narrower frame than many trucks of this era; when looking for beds, you could either look for a highboy bed, or you could source one off a truck with the wider frame and either make brackets or drill new holes in the bed to mount it to your narrower frame. Aside from that, it's just a matter of finding a bed that's not rusty and is the right length for your wheelbase. Start hunting around the junkyards, or looking at Craigslist for a donor truck.
__________________
--Brian
'74 F-100 Ranger (2wd, 302, longbed): http://www.ford-trucks.com/forums/13...sion-swap.html
'01 Mustang Cobra (daily driver, 28x,xxx miles and still running strong)
Old 07-23-2015, 12:03 PM
Ok thanks. How about availability of aftermarket/re manufactured body panels? And floorboards?
Old 07-23-2015, 12:29 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Available are the bed floors, bed sides, head panel, tail gate, and some crossmembers.
I don't recall bed wheel wells nor some of the inner structures being available. Dollar-wise, I think you'd be better off finding and repairing a decent bed instead of starting from scratch.
Old 07-23-2015, 12:44 PM
bkaul's Avatar
It's also worth mentioning that other than the tailgate mounting area, later-model beds up through '96 will bolt on - swapping bedsides + tailgate towers is possible (involves some welding) if you can only find a later-model bed that's rust-free.
__________________
--Brian
Similar Threads
WTB: 76/77 Highboy pitman arm montana_highboy 1973 - 1979 F-100 & Larger F-Series Trucks 27 06-29-2014 01:22 AM
leveling a 76 highboy MJ76 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-13-2014 10:55 AM
Challenge "76 HIGHBOY" started Highboy44 1973 - 1979 F-100 & Larger F-Series Trucks 232 01-08-2014 03:49 PM
HIghboy Bull Bar??? monster85ford 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-11-2012 09:28 PM
76 f250 bed replacement 82ford302 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-13-2010 03:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
