Comp, bore&stoke for 262
Old 07-23-2015, 11:00 AM
Santiagoeford's Avatar
Santiagoeford
Santiagoeford is offline
Does anyone know the compression bore and stroke of a 262 I6? Also. What would litre size be if a 262 is bored .060 over? In litres and Cubic Inch
Old 07-23-2015, 02:00 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
3.72" bore x 4.03" stroke
7.9:1 compression
Old 07-23-2015, 03:03 PM
Santiagoeford
Thanks man. Anyone have any information on if the crank and connecting rods were forged? And what style Pistons were used?
Old 07-23-2015, 07:25 PM
P38fighter's Avatar
P38fighter
P38fighter is offline
I believe you will end up with 279 cubic inches or 4.5 litres approximately.
Old 07-23-2015, 10:57 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
I'm getting about 271 using this one
How to Calculate Bore, Stroke, and Displacement
Cylinders = 6
Bore = 3.78 after .060 over
Stroke = 4.03
271.35
Getting 271.3506 on this one
Engine Design Equations Formulas Calculator Cubic Inch Displacement Bore Stroke
Old 07-24-2015, 09:18 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I believe the cranks are forged, not positive. C rods for sure. Stock pistons are cast flat tops. New stock type pistons are NLA to my knowledge. You could probably have custom pistons made.....would be $$$
Old 07-24-2015, 12:12 PM
Santiagoeford
Cool, what are the purpose of having "aircraft style connecting rods". How is it stronger?
Old 07-24-2015, 05:36 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Where did you get that info from?
I can tell you the 262 rods are much beefier than the 223. Larger rod journals too IIRC....
Old 07-24-2015, 08:19 PM
Santiagoeford
It was a sales ad that said these motors came with "aircraft style rods" and when I asked in another forum I was told it was a bolt That threaded through the cap and into the rod and was told that it was a stronger design
65TIGER
02-07-2008 02:13 PM
Slow
08-26-2005 08:24 AM
TMI
06-02-2005 08:23 PM
46yblock
01-30-2005 01:47 AM
black angel
22
07-22-2002 04:19 PM
Quick Reply: Comp, bore&stoke for 262
