Best oil for hot hot weather
Guys it's time to do some oil change and am using 10w30 synthetic but the truck is eating fuel like crazy and I can hear some kind of knocking when full throttle .
sparks , boots and fuel filter is new .
The mechanic said I should put some lighter velocity oil .
truck odo 130k v10 hot hot weather .
Thanks
Thanks
LIGHTER oil in hot weather? The mechanic is full of more cr*p than a Christmas turkey. I am not familiar with the recommendations for this engine but if there was a need to change I would try a 10-50 or 20-50 synthetic if you are in truly hot conditions.
Is the knocking sound like something fuel related (detonation or "knocks and pings" for the delicate types) or valve rattle?
From 900 rpm up to 3k nothing wrong.
Thanks
Thanks
The rattling may be fuel related, may be a heat shield rattling. I'd look around under the hood, at the muffler heat shield, any shields around the exhaust manifolds, etc. Check your exhaust manifold studs (chronic problem area on V-10s). Have someone rev the engine while you're looking.
Good luck!
Yes from different sources but the rattling is not going away.
No am using synthetic for along time
Actually I do have a tiny manifold leak . but it's not that bad .and the knocking is coming from above not low .
Yeah thanks. I think i would
Your manual recommends 5-20 weight, but 5-30 would be better for hot climates. Synthetic is best, semi synthetic is fine.
Good luck!
Good luck!
Am using Ford sparks , and I have accel coil for 4 years now Running stronge .
Don't use different oil. The motorcraft 5w20 Ford tells you to use is just fine. I used it in hot hot weather nd it was great.
It's likely spark knock. I would not use the accell coils. Go w originals and replace boots too. I've had this on a Ford car as well. As soon as the plugs were replaced and boots inspected it went away.
I think rockauto has the best prices.
if it's still knocking I I'll replace the coils .
With worn spark plugs, I believe the engine tends to run lean because they aren't producing a hot enough spark, so the unburnt fuel detected in the O2 sensors tells the engine to lean it out.
Correct me if I am wrong. That happens quite often.
Thanks
Thanks
I've noticed here on the forum with the V10, guys and gals running the 5w30 use less oil, but get lower fuel economy, and the guys and gals running 5w20 get better fuel economy but use more oil.
Is your engine using any oil? Whats your current MPG?
What kind of temperatures are you seeing? Does it only knock when warm during the hottest times of the day?
I'm getting ready to do my plugs and boots as well. I know they are well over due. I have a little bit of spark knock/pinging going on at lower RPM's when under a load.
And the temperature exceeds the 100 degree .
