2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
recommended rotors?
Old 07-22-2015, 09:03 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
recommended rotors?
I am going to replace the rear rotors in my 07 expy. Autozone and advance sell them for about 70 bucks a piece. Rockauto.com has some for about 30 bucks. Have any of you guys used them? They are pronto brand if that helps any
Old 08-01-2015, 10:40 PM
svtsnakebyte's Avatar
svtsnakebyte
svtsnakebyte is offline
4wd Low
I just put a set of Centric Power Slots on my Naviigator p/n 126.65120SL and 126.65120SR for the rears. I have used power slot rotors for years on different vehicles and had good luck with them, they Make a good quality rotor.
Old 08-19-2015, 12:28 PM
cstanley44's Avatar
cstanley44
cstanley44 is offline
I used Autozone gold last year
no complaints.
They are about $100 each, and coated with a black coating to prevent corrosion. You do not clean it off before using. The pads will clean the wear surface only.
They always have deals, I was able to order two fronts, and get the 25% off and a $10 gift card. Then did the same on two rears.
Old 08-26-2015, 12:20 PM
berry1234's Avatar
berry1234
berry1234 is offline
I used Raybestos professional grade. Work great.
Old 08-28-2015, 11:47 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
I've warped them all, but had the longest lasting and best results with Raybestos. Currently using the Advanced Technology series.
stormyrider
05-07-2009 04:58 PM
stangman516
03-28-2009 12:10 PM
jdecker88
20
02-09-2009 11:27 PM
thebeastof1980
11-21-2007 03:06 PM
jdecker88
08-12-2007 07:32 AM
Quick Reply: recommended rotors?
