Tire size for the '78 F-250 with 4" Lift? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 07-22-2015, 01:34 PM
IdaTater IdaTater is offline
IdaTater is starting off with a positive reputation.
Donald John Tolmie
Hello everyone! I am a new member here, and this is my first post. I drive a '78 F-250 reg cab 4x4, 460 with T-19 4 speed, Dana 60's front and rear with 4.10s and 4" suspension lift. When cruising down the road at 60, shes turnin out 3200ish RPMs. I am wanting to change that with tires and ZF 5 speed (thats for another day). My first question is about the tire size. I want to purchase the MT CLassic II wheels with BFG Km2 37X12.50X17 tires. I think they should fit okay but I thought I would ask before I go spend $2600... TIA
Old 07-22-2015, 01:47 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
35s would be good with 4.10s and overdrive.
Old 07-22-2015, 01:55 PM
Donald John Tolmie
I will put 35s on if need be but the taller the better, that why I am asking if she will tuck the 37s alright.
Old 07-22-2015, 02:01 PM
HIO Silver's Avatar
Depends on the wheel offset and overall width of the tire. Plus tire height/width varies from manufacturer to manufacturer...
I'd be more concerned whether the tires making contact with the frame, body, or leafs at full lock...
Old 07-22-2015, 02:20 PM
Donald John Tolmie
I share the same worries. Thats what I meant to "tuck" the tires alright, asking if they would rub or not. If they rub a little here or there when I am off road, no big deal, but if they rub constantly then I wont go that route. Just trying to knock down the RPMs as much as possible witout taking the 4.10s out.
Old 07-22-2015, 02:45 PM
HIO Silver's Avatar
Quote:
Ah... OK. My reference on "tuck" was how far they stuck out.
The 4.10s need not be removed if going with an overdrive. In fact, they'd be about perfect with 35s or 37s for a mild rig... See, ya gotta think of the each piece of the RPM vs speed equation.. tire height, trans gear ratio, and final drive ratio. I know you're planning on an OD trans later but that's something you have to think of now.
Old 07-22-2015, 05:48 PM
Donald John Tolmie
I have done the math and figured with the combo of the 37" tires and the ZF 0.77 5th gear, the revs would be closer to 2200 at 60 MPH which would be miles better than what is is now. I know the BFG KM2s are 36.8" in diameter and 12.5" wide on a 10" wide wheel. I just don't know if they need to be offset, or if the tires will rub in the first place.
Old 07-22-2015, 10:11 PM
somethingclever's Avatar
somethingclever somethingclever is offline
somethingclever is gaining momentum as a positive member of FTE.somethingclever is gaining momentum as a positive member of FTE.
That is too much tire for a 4" lift with suspension compression and turning wheels at the same time.
I ran that exact wheel/tire setup with 6" lift and it was about perfect Imo.
I will post pics tomorrow.
__________________
1978 F250 4x4 Super Cab - 400, C6, NP205, 3.55, Dump and Plow - Work Horse
1979 F250 4x4 Crew Cab - 466, T18, NP205, 4.88, 9" lift, 40" toyo's - FAMILY WAGON
Old 07-23-2015, 07:49 AM
__________________
Old 07-23-2015, 10:41 AM
Donald John Tolmie
Okay, I will go with 35's then. Thanks somethingclever, I appreciate your feedback. Nice looking trucks you have! I would love to own a crew cab someday....
Similar Threads
1995 LIFT bubbareitz 1987 - 1996 F150 & Larger F-Series Trucks 9 02-23-2015 11:33 AM
78 F150 tire size question VaFordman26 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-05-2013 11:16 PM
Pic request 78/79 bronco 4" lift Cool1996 1978 - 1996 Big Bronco 12 06-19-2013 11:13 AM
Lets see some lifted SuperCabs!!! AntiHero55 1973 - 1979 F-100 & Larger F-Series Trucks 69 10-22-2012 09:19 PM
2wd Tire size mattimeo 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-19-2007 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
