7.3L occasional rough running, got AE, what's next?
#46
I have a pressure regulator shielding the computer from seeing the full boost, not a diode. My waste gate is clamped down pretty far so I build more than stock boost. Should I adjust the regulator up some? I don't like it when the truck puts me in time out for having too much fun!
if it's one like this then pull the **** out and turn it clockwise a couple of turns. Mine was releasing too low as well and had to adjust it. It might take a few tries and some data logging to get it right, but just keep adjusting it until you get it to max out the MAP around 35-36 psi(whatever your baro is plus 22). Or just turn it clockwise all the way then back it off until the check engine ligh stops coming on from the 0238 code.
Get your MAP to level out more in the mid 30's.......
#47
#48
#49
FordPowerStroke
04-23-2014 09:14 PM
johnsk
09-02-2010 08:02 AM
